01-07-2009, 10:48 PM
Aluminum framed bikes..
...Can they be made to live without cracking?
Rubber mounts?
I have an opportunity to get one reasonable with suspension.
I've been looking to update mine with suspension or get another frame.
01-07-2009, 11:34 PM
Re: Aluminum framed bikes..
I would like to build a frame. I have an aluminum frame that is cracked right above the weld that joins the bottom bracket and the seat post tube. I want to use it to get some angles and build a good steel frame. I am a little worried about a motor on an aluminum frame, especially one of the lighter frames.
01-07-2009, 11:50 PM
I have a aluminum schwinn and watch it closly ever sence the report about them cracking; so far getting close to 1000 miles and no cracks yet.
Always do a pre-ride check. Make it a habit, and ride safe.
01-08-2009, 12:58 AM
Watch closely Tex, we like ya!
01-08-2009, 01:33 AM
I have had 3 or 4 aluminum frames and never had a problem. For just street cruising I think they are fine. I wouldn't go jumping curbs or off road with one though. I have at least 1,000 miles on a wally world point beach cruiser thats on it's second Chinagurl. Still looks great. Except for where I "modded" the down tube with a mallet, snork. One great advantage over steel.
Just my thunking
I want 2 ride my bicycle
01-08-2009, 07:43 AM
Thanks for the responses. I'm happy to hear that some are successful.
I'm tempted to try this one and maybe fab some softer mounts, but I also have a shift kit, which may be a challenge.
Yes I'm also a easier rider, but occasionally hit a hole in the road.
01-08-2009, 07:54 AM
Aluminum is just fine for rack mounts.
01-08-2009, 08:13 AM
Awesome O'MB, never know until you try. May I be so bold as to suggest more ridged mounts? All the rubber and softer mountings I have tried only increased vibration. Any room for the engine to move just made for a paint shaker like action and allowed the movement of the piston to jack hammer the whole bike. I could be totally wrong and there is a way to isolate vibration. I have just found letting it absorb threw out works better. If you get a soft mount to work, I can not wait to see and will buy lunch! Would be cool.
I live in CT and pot holes are just part of the fun. The aluminum has done fine. (even the cheap wheels so far although they need TLC about twice a year)((just grease and truing)
Hope to be of help
01-08-2009, 09:28 AM
I don't think the jachshaft kit works too well with rubber mounts and I think Dan has a point. As for aluminum frames, Steel will first crack and show itself while aluminum will just give without warning tending to throw you over the bars.
I'd still try it though, just keep an eye on things.
01-08-2009, 01:12 PM
datz150 came up with some mounts for his aluminum bike for use with the shift kit. No rubber, but they look solid and shouldn't kill the frame. You could probably adjust the size a bit and use a wrap of some kind of rubber....
http://motorbicycling.com/f15/rotten...html#post23028
| Thread Tools |
| Display Modes |
Linear Mode
