01-05-2009, 11:16 AM
Twin Sprockets
Has anyone done this; my brother had an old AMF Harley trail bike. It used two sprockets on the rear and a spring tensioner. You had to switch the gear manually. I was thinking that would work for these bikes. Have a 44 tooth sprocket and a spacer then a 36 tooth sprocket. The chain tensioner would need to be a bit wider and with lots of swing to allow the switching of gears. Windy days 44, calm and flat roads 36.
Always do a pre-ride check. Make it a habit, and ride safe.
01-05-2009, 12:17 PM
Re: Twin Sprockets
i've actually tried this and i couldn't get it to work (a welder would have helped though) you have to bend your frame to make room for the extra sprocket, and the difference in the chain length (from a 50 tooth to a 38) was so large that i had to try to reverse the chain tensioner to push the slack down instead of up. to keep it from rubbing itself on the high gear. do u have any picture of the harley setup? dont try this without a spoke guard!
01-05-2009, 12:53 PM
Re: Twin Sprockets
Those, and the early Honda 90's had two sprockets, one fit over the other. When you wanted to go to the other sprocket, you would remove the masterlink, remove (or add) the section of chain, pull (or push depending on which one you wanted to use) the other sprocket out of the way (it was on pins if I remember right) and re-install the master link.
01-05-2009, 12:57 PM
Banned
Re: Twin Sprockets
That makes sense.
I was thinking the same thing that mechanickid pointed out, and wondered how it was done.
Jim
01-05-2009, 01:14 PM
Re: Twin Sprockets
i think it could be done if the sprocket size wasn't very big and you had a well adjusted tensioner/derailleur.
one of the reasons i gave up was because it would legally be a motorcycle if it worked, same with the shifter kit (much better way to go im my opinion)
01-05-2009, 01:37 PM
Re: Twin Sprockets
I don't think on the harley you took the master link out, But it might have to have a derailer type tension wheels to take up the slack
01-05-2009, 01:42 PM
Re: Twin Sprockets
I've been toying with this very concept for several weeks. My problem is frame width too. I've already built a sliding chain tensioner that would (manually) guide the chain from one sprocket to the other. I couldn't keep the chain from hitting the chainstay on the outer sprocket and I didn't want to skin up the paint with an experiment. I'm going over to a guys house this afternoon to look at his collection of old bikes. If I can find what I'm looking for, an old cruiser with fat tires, I'll buy it, if it has a wide stance in the chainstay area. My bike is just too skinny, like its owner, for the double sprocket idea. Maybe a fatter bike. I'll keep you posted.
01-05-2009, 01:57 PM
Re: Twin Sprockets
Thanks, even if you had to take out a master link, it seems a cheap way of making your bike more versatile. If you could aford the 7 speed hub and jack shaft set-up, then thats a whole lot better.
01-05-2009, 06:38 PM
Re: Twin Sprockets
Would You Need A Front Derailer When You Use The Out Of Line Rear Sprocket. I`m About To Install My Sbp Shifter Kit On A "barnes" Schwinn Cruiser Style Frame. It Has A 5 Speed Rear Cassette. Are The Shift Kits Needing To Use A Front Derailer?? I Will Soon Find Out. Anybody Heard Of "barnes" ?? It Has A Decal Head Badge, Barnes Accross The Top And A Couple Of Lions Below, "bicycle Pedal'r" On The Bottom.i Would Post Pics, But They Are Too Large. Steel Frame. Tire Size UP To 26 X 2.125
PUMP YOUR BRAKES  HAVE TO LOVE WINDOWS & THE INTERNET
NEVER BEAT ON IT, GET A BIGGER HAMMER
"A MAN WHO SAY`S IT CANNOT BE DONE SHOULD NOT INTERRUPT A MAN DOING IT"
01-06-2009, 04:04 AM
Re: Twin Sprockets
Cool thought Dav. Been wondering for a wile if a bicycle style derailleur could be used. #41 sized and the reverse of the rear, right side bike derailler. Be big time $ to have one made but great if it could be done! Can spread the dropouts and chainstays....
I want 2 ride my bicycle
| Thread Tools |
| Display Modes |
Linear Mode
