Old 03-27-2014, 02:57 PM
Default Re: does anybody beleive these power claims are accurate?
Without mentioning the brand but showing some specs on this 4000 watt stereo amplifier, you would wonder how it is 4000 watts
If 8 Ohms into two stereo speakers it does 250 each that is 500 watts
They don't mention you can use it in 2 ohm speakers so the Distortion Spec is just for 4 or 8 OHM.
They call it 4000 watts by considering as if it were to be used into 2 OHMS.
Then 2 is 1/4 the resistance of 8 and 500 * 8 equals 4000 watts. 2000 watts into 2 separate stereo speakers that you cannot use without compromising or maybe even damaging your amplifier.
The rating also of 4000 watts you would not usually be using anyway, what it does is allow at lower volume setting at less power give less distortion.
What I mean is comparatively if you use a 1000 watt amp and set to the same volume level you would likely get a bit more distortion. Its like having a bigger power reserve you never intend to use on the higher output amplifier just so it sounds better.
I'm not saying the products are not good, but I think it is deceptive advertizing.
Power Output:
8 Ohm Stereo: 2x250W RMS
4 Ohm Stereo: 2x350W RMS
8 Ohm Bridged: 700W RMS
Total Harmonic Distortion: Less than 0.1 percent
Input sensitivity and Impedance: 0.77v
Signal to Noise (20 Hz 20 kHz): > 90dB
Find me an electric motor that is 2 ohms and has the same voltage as this amplifier and you have 4000 / 746 = 5.4hp that plays in time to the music.
See apples and oranges
Old 03-27-2014, 08:04 PM
needtransportation needtransportation is offline
Not sure how this turned into an audio thread but my last stereo was a pioneer 4900ib, head unit, cadence txa 1000d amp running a diyma12 ( damn i miss that sub, she was so clean and well blended while still crisp) in 1^ft sealed, txa 6004 running the mmats 6.5.1 three way comp set with the mid and tweet in fiberglass kick pods and the midwoofer in sealed doors with the doors, floor, and trunk deadened with raamat. Was super clean with almost no distortion and chest pounding midbass that blended smoothly with bass.
