Old 01-04-2009, 07:12 AM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Default smll Emotor wanted
Im looking for a small electric motor from the smallest e scooter made. usually they are 24volts and about 100 to 180 watts. they come with a small sprocket on the front. If you have one of these laying about I sure could use it if the price is right. It's for testing on my ebike build.
just message me.
Old 01-04-2009, 07:22 AM
Weedylot Weedylot is offline
Angry Old Fart
Default Re: smll Emotor wanted
Hi Deacon, I'm almost to the point of taking the motor off my Ford Thinkbike. The bike has mysteriously quit, but the motor is OK; I think. After some research I discovered that the Thinkbike may have a "bad board" that is not easily fixed.
The motor is mounted with the output shaft pointed rearward into the crank set. Kind of an oddball setup. It is about 450 watts.
I've
also got to dig out a power riding toy motor that's about 200 watts. Its somewhere in the shed...
The only normal people are the ones you don't know very well.
Old 01-04-2009, 10:20 AM
deacon's Avatar
If your motor is brushed type you can bypass the board and have a simple on off switch to the motor. It should work just fine as a bike. You probably can still use it just fine.
I really want something under 200 watts. The smaller power toys might do it though. I appreciate your thinking of me lol... If the power toy is small enough let me know we can work something out.
