Old 12-31-2008, 03:46 PM
Michigan Mike's Avatar
Michigan Mike Michigan Mike is offline
Default Push Trailer
I wonder if a motorized one of these would make a good push trailer?
Michigan Mike
"There's never a reason to be unkind."
Ravi Zacharias
Old 12-31-2008, 04:08 PM
DOC BOLM's Avatar
DOC BOLM DOC BOLM is offline
Default Re: Push Trailer
Mike looks like the hitch setup would need to fixed so it could not turn.You might have steering problems.Harleys Dad
Old 01-01-2009, 07:59 PM
What engine and drive system are you thinking of using?
Old 01-01-2009, 10:57 PM
Hi 5-7HEAVEN,
I was thinking something simple like just adding a friction drive on this. (I believe you mentioned the same thing.?)
Sounds like it might work ... but I'm no engineer. Not sure how safe it would be since I don't know what stresses might be involved ... just couldn't resist mentioning it for discussion purposes.
Happy New Year!
Michigan Mike
Ravi Zacharias
Old 01-02-2009, 12:48 AM
Hey Mike,
Rear friction drive would be the simplest and easiest. If you do it yourself with a weedwhacker/chainsaw/edger motor, it can be as cheap as $100 or less.
If you use a new Staton with Subaru or Honda 50 engine, installation is less than two hours but cost is $499-$769, not including shipping.
Whatcha going do, climb hills or ride flat ground?
How fast ya wanna go, 20mph or 30mph?
Old 01-05-2009, 09:36 AM
Hey Mike,
Hi 5-7HEAVEN,
Sorry for the delay in answering your post ... I thought I had replied already but I don't see it here in thread.
Mainly I just want to geezer-around my little town. Not much in the way of hills here and the roads are good two-lane blacktops. Top speed of 15-20 would be OK with me.
Actually I'm just about certain that I'll be going with a Stanton friction setup w/ 35 Robin/Subaru 4-stroke no matter which bike I end up with. I've only heard good things about this rig.
Thanks again for your input ... much appreciated.
Michigan Mike
Ravi Zacharias
Old 01-24-2009, 01:52 AM
Mike, I've been thinking...
You're only asking to go 15-20 mph. You don't really need a trailer.
All you need is any 2-stroke engine, 7/8" roller and friction drive on your rear tire.
Doable for $100 WITHOUT the trailer.
