| Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack |
03-19-2008, 08:48 PM
How tight should I tighten the sprocket bolts?
03-19-2008, 09:02 PM
Re: How tight should I tighten the sprocket bolts?
I used 1/4" drive ratchet and tightened about as tight as I could with one hand. I didn't get brutal or anything just good normal tight. I started out with them just snug and went round and round tightening them trying to keep sprocket straight. Hope this helps.......................
03-19-2008, 09:54 PM
I should have read the instructions that came with my kit instead of looking at those picture instructions from zippycycles.com ! The photo of the sprocket shows both rubber washers on the inside of the spokes, rather than one on the inside and one on the outside like my instructions say. I have a feeling my instructions are right, what did you guys do?
03-19-2008, 10:00 PM
Administrator
yes one on inside and one on outside. here is a pictorial on installing the sprocket http://motorbicycling.com/f30/motori...ocket-381.html the pictorial is about changing out site of you sprocket but great for initial installation also
03-19-2008, 10:20 PM
This forum is so great, you guys are really helpful and nice! Thanks
03-19-2008, 10:28 PM
The instructions I saw recommended a rubber washer on inside and outside only for bikes with coaster breaks. I'm not sure why that would make a difference.
03-20-2008, 08:02 PM
LORD VADER Moderator
Follow our instructions and you will be successful if you don't understand anything don't be afraid to ask. I use the fiber gasket on both sides to get a good grip on the spokes, keeps the sprocket off the spokes, provides space to aline the front and rear sprockets.
Norman
03-21-2008, 06:47 AM
One on the inside, one on the outside, it's the only way it will work and keep working.
03-24-2008, 07:38 PM
Listen to Joe.
Norman
03-24-2008, 08:12 PM
minor bike philosopher
I agree its the only way that makes sense. Metal and metal will never grip like that wrap around fiber.
I tightened mine till I felt like the nut stopped moving, not till the puller handle bent. But you should check it now and then, as it will probably get loose after a while. Everything gets loose after a while
| Thread Tools |
| Display Modes |
Linear Mode
