Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Old 12-30-2008, 05:43 PM
stuartracing's Avatar
stuartracing stuartracing is offline
Default Sealing engine......
Well I totally sealed the engine cases at the split with gray silicone....Now the engine is running soo rich I can`t lean it out enough to even ride it.....I tried the needle all the way up,down in the middle,filter, no filter,different baffle configurations,different carb. `s(stock).....I guess I need to solder a jet and redrill it huh....Or take the sealant back off.....I sealed the cases because my other motor was leaking there like a chimney,boat,ballon,whatever it is....So before I installed this motor, thats what I did.....
Paul.....
Life in the Fast Lane......
If your living on the edge , you`re taking up too much space....
Old 12-30-2008, 06:28 PM
Bikeguy Joe's Avatar
Default Re: Sealing engine......
I would re-drill, your bike engine will love you for it.
Old 12-30-2008, 06:34 PM
Yes I guess thats my only choice....But I did order a CNS carb. but it`s gonna be a while before it gets here.....
P.....
Old 12-30-2008, 06:37 PM
Those are the shiznit from what I hear. At least they are adjustable.
Old 12-31-2008, 12:25 AM
wildemere wildemere is offline
File 2 or 3mm of the bottom of the slide.
Measure and duplicate the cutaway on the slide.
Works well for those carbs that are too rich, gets the needle back in the middle again.
Old 12-31-2008, 07:57 AM
Please explain a little better, I don`t quite understand....
Paul.....
Old 01-01-2009, 02:10 PM
take the slide, put it in a vise and file the bottom of it shorter by 2 or 3mm
measure it with a caliper before and after filing.
make sure it has the same profile ( the cutaway )
this leans out the carb by 2 or 3 needle positions.
Study a 2 stroke tuning guide if this means nothing
I would start with Gordon Jennings 2 Stroke Tuners Handbook.
Old 01-01-2009, 02:38 PM
Yes I understand now....I will check it out....THats exactly what I`m needing to do to this motor....
Thanks alot.....
Old 01-01-2009, 03:24 PM
That is a great tip!
I learn something new (almost) every day.
Old 01-01-2009, 04:50 PM
toytime toytime is offline
Here is a link; Gordon Jenning's Archivek
