Old 12-30-2008, 12:15 PM
hagadoja hagadoja is offline
Default 1st post... Can't get it fired !?
Been lurking for a week or so. thanks for all the ideas you all have unknowingly helped me with but I still haven't got this thing to fire.... I have a Cruiser with the Raw 80cc completely installed. I just tried riding it and the clutch was rubbing so I fixed that. Now when I release the lever it sounds like it wants to start but nothing happens ?? Where should I start ? How do I check for spark ? It is getting gas cause I drained the float bowl. Any ideas ? Also, does it matter if I extended the wires from the coil to the engine about 6 inches ? that is about the only mod for assembly that I made.
Old 12-30-2008, 12:22 PM
Ilikeabikea's Avatar
Default Re: 1st post... Can't get it fired !?
You can take the plug out and lay it down on the top of the engine and spin the engine over and see if plug sparks. If it doesn't the first thing to try is take the kill switch out. Hook the mag straight to the coil. That's the first thing to try.......................
Oh yea, and Welcome to the forum. Glad you joined us......................
Old 12-30-2008, 12:35 PM
DOC BOLM's Avatar
DOC BOLM DOC BOLM is offline
Did you hook the ground wire to a good ground.Mine shook loose and i went dead. HARLEYS DAD
Old 12-30-2008, 01:06 PM
I'll try that now.... thanks
Old 12-30-2008, 01:07 PM
drilled a hole in the frame and attached it securely. thanks
Old 12-30-2008, 01:12 PM
hill climber hill climber is offline
what ground wire?
Old 12-30-2008, 01:31 PM
Originally Posted by hill climber View Post
what ground wire?
off the bottom of the engine there are 3 wires, the blue the black and white. the blue and black connected to the coil and the white went to ground ?!?!
Old 12-30-2008, 01:33 PM
ok, disconnected the kill switch NOTHING
checked for spark by removing the sparkplug and laying it on top of motor, turned motor over NOTHING no spark.....
Old 12-30-2008, 01:39 PM
what ground wire?
thanks Hill Climber.... I assumed the white was ground....
Read your reply and a light went off above my head (seriously) it was the hall light but still...
I ran downstairs disconnected the white wire from ground and VOILA I have spark !!!
I was so excited I ran upstairs to share before I went on my maiden voyage !!!
Old 12-30-2008, 01:51 PM
right on, glad i could help. some use the white wire to run a light and some use it for a kill switch. my recomendation is to just cover it and forget about it. i kill my engines by letting out the clutch slowly. and for light i use a sealed lead acid battery, about 5 amp hours. with a 55 watt driving light and a led tail light i get about an hour of GOOD light.
