Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Mechanical Components > Heads and Cylinders
Heads and Cylinders All about your porting, compression, rings, cylinder and piston modifications to your bicycle engine
Old 12-29-2008, 04:29 PM
mechanickid's Avatar
mechanickid mechanickid is offline
Question head gasket questions
Hey guys, so i figured out i had an air leak after i peddled up a hill with the engine off and the clutch engaged trying to start it.
when i took the head off i found a metal spacer where the gasket should be, but no gasket.
im thinking i could just replace the spacer with a gasket and that would improve compression greatly, has anyone tried this?
Old 12-29-2008, 04:32 PM
Bikeguy Joe's Avatar
Default Re: head gasket questions
That is the gasket.
Old 12-29-2008, 04:40 PM
Dave31's Avatar
Dave31 Dave31 is offline
Head Gasket Pic from...ThatsDax
ENGINE_KIT_PARTS_PAGE_2
Old 12-29-2008, 04:47 PM
how is that supposed to seal well?
Old 12-29-2008, 04:51 PM
It's a soft aluminum...it works very well, and in fact most engines have a similar type of gasket...or sometimes annealed copper. The only head gaskets I've ever seen with "gasket material" have an aluminum ring where each cylinder is.
Some guys (Norman) have use a heavy aluminum pigmented paint as a "gasket".
Old 12-29-2008, 05:16 PM
ah, well i replaced it with some cardboard and grease. dumb, i know, but it was worth a try. it did improve compression a bit. but i still have an air leak somewhere between the air filter and the engine.
Old 12-29-2008, 05:20 PM
A leaking head gasket will manifest itself as an air leak too.
What did you do with the old gasket?
Old 12-29-2008, 05:21 PM
You could always use to "hillbilly chrome" paint or Rustoleum aluminum paint if the cardboard and grease don't hold up.....I think the correct gaskets are cheap though.
Old 12-29-2008, 05:24 PM
Thebest thing to do for the air leak is to just remove the carb and intake, make a new gasket out of some gasket paper, or carboard and SILICONE like RTV sealer, and put it back together.
In a pinch, just remove it and goober up the old gasket with silicone....any kind will work, even 100% silicone caulking.
Old 12-29-2008, 06:09 PM
i left it out but kept it. sounds good! thanks Joe
