Old 06-19-2008, 11:26 PM
Joshua Joshua is offline
Default Clutch cable/adjustment issues
I have a china motor and I have the clutch cable adjusted so there is no play in it. when the bike is running if I lock the clutch in with the button it still wants to go somewhat, is this normal. If I pull it in by hand all the way the clutch seems to disengage completely. I know my first thought is just tighten it a bit more but I'm worried if I go to much the clutch won't engage completely and it will burn it up. Is this a problem, do I need to adjust the clutch its self or tighten the cable even more.
Old 12-28-2008, 03:30 PM
Hot Dog Piggy Tails's Avatar
Hot Dog Piggy Tails Hot Dog Piggy Tails is offline
Default Re: How do you port and polish
You need to get a different cable . You can use a Brake cable for Bikes. It will have less give and will fully disingage your engine from drive train
Old 12-28-2008, 07:45 PM
stuartracing's Avatar
stuartracing stuartracing is offline
Default Re: Clutch cable/adjustment issues
It`s really not a problem...It`s just that the lever/button won`t pull in as far as you can with your hand.....Won`t really hurt anything as long as it doesn`t pull the bike hard....Mine pulls a little,like on the stand with wheel off the ground it spins, but on the ground I can`t really tell....JMO...
Paul...
Life in the Fast Lane......
If your living on the edge , you`re taking up too much space....
Old 12-28-2008, 08:32 PM
2door's Avatar
2door 2door is offline
Stuart is right. It won't hurt anything but it can be a bother. You can adjust your clutch cable a bit tighter to get rid of the problem just don't get too aggressive with the tension. My bike will not pull itself but there is a difference in RPMs when I'm at a stop sign with the clutch lock engaged and idling. After some time you might need to re adjust because of cable stretch. Enjoy and don't hesitate to ask if you have questions.
Old 12-29-2008, 07:22 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
you might be able to adjust the star nut about 1/2 turn or 1/4 turn to get it where the clutch lever when pulled in and resting on the clutch disengagement pin will not spin the rear tire/ no clutch drag at all. Play with the star nut it some times will be your friend don't forget to reinstall the very small hateful little set screw and a dab of lictite or steal the ol ladies finger nail polish and dab a little on the screw, heck a nice set of fresh polished nails will really impress your buddies or they might steer clear of you for a while who knows!
Norman
norms-iron-works.tripod.com
Old 12-29-2008, 09:15 PM
2door's Avatar
Norman
Norman,
"Lictite" I've never used it but it sounds kinda sexy.
Old 12-30-2008, 07:10 PM
Norman's Avatar
oooooooooppppppppppppppsssssssssssss!!!!!!!!!!!!!! !
I didn't spell check that one it does sound kinky and nasty,,,,,,,,, I like it.
A new product" lictite" the more you lick it, the more they like it.
need an evil grin thingy.
Norman
Old 01-21-2009, 07:22 AM
TigerToothBikes.com's Avatar
TigerToothBikes.com TigerToothBikes.com is offline
UK Dealer
what? with normans lictite? heard a certain film industry had adopted it and was using it on their models!
For EU and UK Kits/Parts/Fully fitted bikes.
Visit us at
www.TigerToothBikes.com -
'Engines Ignited By the Finest Cigar'
"Tigertooth built him a jet
When his parts come in he'll be set
The pulse was so cool
It'd make a guy drool
He'll put one on a bike now I bet....................." - Ilikeabikea
Old 01-21-2009, 07:25 AM
Bikeguy Joe's Avatar
That's normal, read stuartracings response. The fix for it is to pull in the lever all the way.
Old 01-21-2009, 12:38 PM
jasonh's Avatar
jasonh jasonh is offline
What they all said. Pretty much normal. You might try adjusting the star nut a bit if it's dragging too much. Go one notch at a time.
