12-25-2008, 09:09 PM
electric start on 70cc
anybody conquer the electric start on the Chinese 70 cc frame mount motor yet? i have a problem with my back and sometimes I cant start the motor. Briggs and Straton has 12v starters for about 45 bucks and Ive got some ideas but...
12-26-2008, 06:19 AM
Re: electric start on 70cc
The only reason you'd need an electric leg is if you had two broken ones of your own....then you couldn't ride a bike anyhow.
12-26-2008, 08:15 AM
is a great idea. thunking a 4 stroker with electric start adapted would be more worth it. With a chinagurl where would you drive it from? Has the shaft forward but then you would have a lot of moding to do. dunno, but would be awesome if you can get it to work Lilhog.
Half the fun is all the dreaming up
I want 2 ride my bicycle
12-26-2008, 11:57 AM
I'm going to try an e-start on mine eventually, once I get a battery and stuff. Any high-torque 12v motor should do it...a drill, etc. I'll be using a motor from a 12v impact wrench.
12-26-2008, 04:08 PM
Well if you had an electric front hub drive and the 70cc two stroke, problem solved and two wheel drive for snow.
Always do a pre-ride check. Make it a habit, and ride safe.
12-26-2008, 05:04 PM
Kewl thought Dav!! Gotdang!!! what a fascinating... dunno
Very kewl, simple, will work solution. and has other advantages. That would sell as a completed bike. if the rear hub was a gen.. man that would be a BA MB!
12-27-2008, 06:49 AM
If you are going to use a 12v starter, use one from a car, then attatch a sprocket to it and power the bike with it as well. All the weight of a starter and a 12v battery that you will have to re-charge will require a little extra oopmph anyways.
I love the front hub idea, and you could recharge the system while on the fly.
| Thread Tools |
| Display Modes |
Linear Mode
