KoolBreeze420
I just got my motor kit installed and I am wondering about a few things first the carburetor in what direction do you turn the idle screw to shut the fuel off so if i need to increase or decrease the idle which direction does what?
The clutch cable has 2 springs one to protect from heat but what is the purpose of the other? I think it goes in between the cable housing and the idle arm. Is it really needed?
The problem I am having is when the spring is installed, I can't get the clutch arm far enough so that when I pull the clutch it disengages. The other issue is the chain how tight is too tight? And does anyone know how to put the chain guard on?
