Old 12-22-2008, 01:19 AM
popp314 popp314 is offline
Default New Guy question
Would a 24' bmx redline bike be ok to use? and what motor do you suggest, 50 or 80 motor?
Old 12-22-2008, 08:18 AM
Bikeguy Joe's Avatar
Default Re: New Guy question
Can you post a picture? You'll need 12+ inches from the bottom bracket to the top tube plus some room fore and aft...no rear suspension.
I would go for the 70cc, same size and weight , more torque.
Old 12-22-2008, 09:39 AM
Technocyclist's Avatar
Technocyclist Technocyclist is offline
If it's a steel frame, then it should be Ok. Avoid aluminum frames. I would suggest a pocketbike engine so it can fit inside the frame, however you'll need extra wide cranks. A rack mount would also be advisable for a small frame.
Welcome to this motoring thingy and enjoy the build as well as the ride...
Regardless if it's left or wrong, the opposite is always right.
Caution: This hobby is habit forming.
Old 12-23-2008, 01:51 AM
hiker472's Avatar
hiker472 hiker472 is offline
The 50 and the 80 are both the same size. The reason why Joe mentioned the "70" is because there is no such thing as an "80", but nevertheless, that's what everyone "sells" them as, when in reality the 80cc is actually 69cc.
Don't feed the bears....
Old 12-23-2008, 01:58 PM
jasonh's Avatar
jasonh jasonh is offline
If it's anything like this bike
REDLINE | BMX RACING BIKES |
You're not gonna fit a motor in the frame. You can go rack mount though. There is someone here that put a souped up motor on the back of a bmx...
