Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle > Motor Bicycle Safety
Motor Bicycle Safety Share safety tips for motorized bicycles. Some of these bicycle engines will reach great speeds and need respect.
Old 03-17-2008, 09:20 AM
Autocycler's Avatar
Autocycler Autocycler is offline
Exclamation Driver Awareness Test
Check out the attached test...
DOTHETEST
Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
Old 03-27-2008, 12:26 AM
nogoodnic's Avatar
nogoodnic nogoodnic is offline
Default Re: Driver Awareness Test
That was cool, thanks Auto...Kelly
I'm racin' Spitfire, turnin', poppin' wheelies, burnin' evil chasin' pop,pop, pop,pop,pop.... (The Pixies-Tony's theme)
Old 03-28-2008, 03:14 PM
Dave31's Avatar
Dave31 Dave31 is offline
The Golden Rule: Always ride assuming you have not been seen!
Your ability to identify and anticipate potential hazards BEFORE they become problems is a vital one. Make it your new best friend.
Old 04-02-2008, 08:10 PM
jezusjonz's Avatar
jezusjonz jezusjonz is offline
Even when they stop look right at you and STILL pull out in front of you!
grrrrrrrrrrrr...
Old 04-11-2008, 07:34 PM
drummer_thing drummer_thing is offline
I need to learn to moonwalk like that.
Old 04-26-2009, 06:59 AM
fm2200 fm2200 is offline
That was a real good example of how the average driver would make the quick observation when pulling out from a side street in front of you. We are the Bear
Old 04-26-2009, 07:24 AM
I was just missed being hit by a Jeep the other day and what occurred to me that afternoon is that some drivers or probably half the drivers on the road will never perceive that a bicycle should be traveling at anything over 10mph max. So when they glance in your direction for that brief millisecond there not evalutating your speed, there looking for another car or truck, or something that will cause significant damage to them should they move in it's intended path. I now firmly believe that this is the most dangerous form of getting around, yet I continue to ride in the hope I don't have that life altering accident with another vehicle. I now fully understand that they will never learn that some bicycles are moving at a greater rate of speed than the normal cyclist does. I use a very bright headlight which helps most of the time, but not all of the time. Ride somewhat cautiously because they won't.
