Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Old 12-18-2008, 10:34 PM
Smallwheels Smallwheels is offline
Question I Need A New Carburetor
This is my first post here. I've been around on other forums so I'm not necessarily new.
While pull starting my Golden Eagle 32cc Tanaka 3300 motor my glove caught on the air cleaner. The air cleaner is attached directly to the plastic carburetor. It broke the carburetor. Essentially everything above the metal air intake came off. Golden Eagle doesn't stock parts so they couldn't help very quickly.
Is there an aftermarket carburetor that will bolt onto this motor that also is made of metal? I would prefer no plastic parts. It doesn't even need to be a high performance carburetor because I don't want to get a new exhaust system.
For now the motor runs if I carefully press the part back into place. It only takes a little pressure to dislodge it and make it inoperable. It also runs slower in the lower RPM range too. I would like to have it running better by Christmas. Maybe by then this extreme cold weather will be gone.
Thank you for your help.
Smallwheels
DoNotDieYet.blogspot dot com
Old 12-18-2008, 10:55 PM
misteright1_99's Avatar
Default Re: I Need A New Carburetor
I would check with Tanaka directly....Here is a link to help find a dealer.........
32209 PERFORMANCE PACK, 33cc
"No such thing as a stupid question, just a stupid answer"
48cc Grubee Starfire Round Head......
Last edited by misteright1_99; 12-18-2008 at 11:02 PM. Reason: Added Link.........
