Old 12-18-2008, 11:05 AM
mostyn56 mostyn56 is offline
Question White wire Question
As the white wire from the magneto on a HT engine provides some output, could it be connected to the blue wire to provide a stronger spark at lower rpm.
I ask this because, since fitting a pullstart, I'm finding it more difficult to start.
Old 12-18-2008, 11:09 AM
jasonh's Avatar
jasonh jasonh is offline
Default Re: White wire Question
I doubt it would work out.
If the motor is hard to start, check your plug and wire. If you're using a stock plug, that might have something to do with it.
Old 12-18-2008, 11:24 AM
Hi jasonh, I have a new NGK6HS fitted & a good lead.
I just think the speed at which I'm spinning it over by hand is not as fast as pedalling & releasing the clutch. Maybe I need to visit the gym so I can pull the rope harder!!!
Cheers.
Old 12-18-2008, 04:52 PM
Bikeguy Joe's Avatar
Push the tickler for a second longer.
Old 12-18-2008, 06:41 PM
Thumbs up Re: White wire Question
Thanks Bikeguy Joe, I tried giving it extra tickler & it definitely started a lot easier.
I tend to only give it a couple of pumps as the only other carbs I've had a tickler on was my old Norton's, Triumph's etc. If you gave them too much tickle the fuel would always overflow. These little carbs can take an amazing amount of tickling without splilling petrol over the rest of the engine!!!
Old 12-19-2008, 05:46 AM
A lot of it goes down the intake on these, so be careful.
You almost can't flood a two stroke when it's cold, the extra tickler seems to work great. I usually don't even use the choke anymore.
Old 12-19-2008, 09:37 AM
You're right, I can see now that the fuel would run into the intake before spilling out.
I'll bear that in mind when I'm "tickling" her in future. Cheers.
Old 12-19-2008, 02:51 PM
jasonh's Avatar
hmm, interesting, I never thought of using the tickler to get a bit of fuel in there instead of the choke. I rarely push the tickler anyway though, so no reason to start now
