Old 03-17-2008, 06:47 PM
ran49's Avatar
ran49 ran49 is offline
Default Re: drive sprocket
Got her fired up and went on down the road!Less than a mile as I was hearing some noises I didn't like and was half expecting the chain the chain to fly off.
This squeaking noise turned out to to be the lower chain slapping on the wheel even though there is about 1/8" clearance at rest.Anyway for peace of mind I'm going to upgrade chain and sprocket.I see Dax sells a "Precision Super Duty" chain,probably the same one I have now.They also sell a 1.5 mm wide 081 engine sprocket counter shaft sprocket. Good for 415 and 081 chains.Just what is a 081 chain?Any thoughts on this setup. Thanks,Ron
I should mention my bike seems to run smooth and I can see this is going to be a blast.
Old 03-18-2008, 12:19 AM
Egor's Avatar
Egor Egor is offline
Originally Posted by ran49 View Post
I got the kit from boygofast.Guess I'll pull the sprocket off and relieve the teeth a little.The chain fits the rear wheel sprocket fine.Right when you think your getting close boynogo.
Hate to think the chain and sprocket are a mismatch.Thanks,Ron
Keep carving those teeth are not close to correct from the kit. You can use the rear sprocket for a contour and you can make the front teeth smaller, it is a smaller circle, it will work. Have fun, Dave
Old 04-14-2008, 08:25 AM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
if the chain has clearance but is slapping the tire, you probably have too much chain on the bike. Too much slack in it. just a guess...I must have gotten lucky I have that kit and mine never had a moments problem with the sprocket.
Old 04-14-2008, 09:22 AM
Ghost0's Avatar
Ghost0 Ghost0 is offline
I have run into similar problems with my builds but I usually don't sweat it. Usually after about a mile or 2 the chain and sprocket break in and they mesh fine. I do suggest that your chain tension be adjusted correctly though, sounds like you had it a little loose if it was hitting the tire. I just tweaked the tensioner to move the chain away from the tire and also the shorter the chain the better. If you can remove links I would.
Old 04-14-2008, 09:26 AM
paul's Avatar
paul paul is offline
to add to this keep your chain well lubbed. i had a few tight spots in mine and kept lubing till it was correct
Old 04-14-2008, 05:10 PM
If there is only and 1/8" clearance and the chain is hitting the tire, I'd say don't sweat it. That's pretty close, but where's the chain gonna go?
It's gonna ruin your white wall anyway.
