12-17-2008, 05:48 PM
JB Weld-What Can I expect:Exhaust ?
Hey you All, hows it goin ?
I have an Exhaust problem hooking up a non custom Exhaust it looks like a
weld job is needed, . . but for now I'd like to fasten some parts that will be under pressure from the cylinder exhaust, . . . .
is there a chance I can use JB Weld or what, . . . does anyone have any experience with it ?
From what I read about it working on oil rigs and bulldozers, I am thinking, . .
is this a lot of bull ?
12-17-2008, 06:10 PM
Re: JB Weld-What Can I expect:Exhaust ?
jb weld is amazing stuff, you can pretty much do anything with it. it should be no problem for your exhaust
12-17-2008, 06:15 PM
I haven't used jb weld for it, but it'll probably work. Just gotta watch out for cracks that may develop due to vibration.
I use that muffler repair putty junk and it works, but cracks after a while, requiring another application.
12-17-2008, 07:56 PM
Santa Cruz Scooter Works
I've tried in a bind during one of my kart races when my header pipe cracked. JB Weld is great stuff but with the vibration and extreme heat, it didn't hold up. If its at a place where it doesn't get too hot or vibrate, you might be okay. Good luck.
12-17-2008, 09:06 PM
Heat is JB welds worst enemy. Heat will make it come all to pieces.....................
12-17-2008, 09:19 PM
Thanks for the feed back !
Well, I with the pessimist concerning heat and vibration, in other words I agree, like I had to solder a part close to the manifold it held for a few minutes but when the heat got up it popped out and failed, I have re soldered three times and the last time I tacked it on pretty good, but my guess is it won't hold, How hot does that get ? I was told around 250 f.
but don't know for sure and tin lead solder is pretty soft.
Looks like maybe some welding !
12-17-2008, 09:23 PM
Brazing would probably work pretty good and is fairly easy to do. I prefer wire feed welding. Thats my favorite way......................
12-17-2008, 10:16 PM
I'm sure if you have everything ready to go. A welder would do it for under $20. Please learn for my many mistakes. LOL Do it right the first time. It will save you money and time. I've learned the hard ways many times. I would spend a few bucks at a time fixing something that would be a temporary then finally kick down the money to finally do it the right way.
12-20-2008, 10:03 PM
Muffler patch kit worked for 1 day for me, before the hole worked its way around to the other side and made the muffler break in two pieces. If its a hole that doesn`t cause structural damage(IE a puncture vs. your muffler cracking in two pieces from vibration and heat.) I`m guessing the patch kit will work but it doesnt look pretty.
12-22-2008, 07:51 AM
Gotcha on the patch kit, I used some stuff called, DEVCON, metal patch fill, with a couple of tries and then layering over screw type hose bands, I finally got it to hold, It's not to bad so far!
I know it's temporary, and I'm gonna do some permanent work.
But it's doin the job.
Thanks much bikers !
| Thread Tools |
| Display Modes |
Linear Mode
