Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 12-16-2008, 07:56 PM
Friction's Avatar
Friction Friction is offline
Question Throttle Cable
Hello everyone I was just wondering how I could attach my throttle on my weed wacker bike to my rear v brake cable? got any ideas ??
my cable is really short
Old 12-17-2008, 04:38 AM
Bikeguy Joe's Avatar
Default Re: Throttle Cable
What kind of end does the carb use?
If it's the clamp on or ferrule style, go for it.
Old 12-17-2008, 07:19 AM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
To marry your throttle cable do the following.
"Go to the auto supply store and get yourself a pack of electrical wire connectors crimp type. Take one and run your throttle cable through it then back through leaving a loop at the end. Then crimp it down good. Now use a pair of plairs to flatten the loop.
Do exactly the same to the brake cable. inter coking the loops. It is very important that you mash the loop blat. That take the pressure off the crimp.
that should be light enough to return the carp throttle.
But take a look at the carp and see if you cant remove the throttle cable and install your brake cable directly to it. Sometimes you can and if so it is better to have one cable than to marry them
Old 12-17-2008, 12:30 PM
Friction's Avatar
thanks for the help
