Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 12-15-2008, 12:04 AM
hill climber hill climber is offline
Default 25cc gear ratio
can anyone let me know if 20.5:1 is enough gear for a 25cc motor on a 26" mountain bike. i am not looking for a lot of speed. i know 25cc is enough on a friction with a 3/4" roller, pulls from a stop to about 23mph. anyone have any idea of rpm on a craftsman 25cc hedge trimmer, 2 smoke of course.
thanks,
hill climber
Old 12-17-2008, 01:28 AM
Default Re: 25cc gear ratio
No, the 20:1 ratio would not work. It is equivalent to a 1.46" roller.
If you say that a 3/4" roller scoots to 23mph, that engine is screaming at 11,648 rpm...
which is equivalent to 39.2:1 gear ratio at 11,648 rpm...
or a 33.6:1 ratio at 10,000 rpm...
or a 30.3:1 ratio at 9,000 rpm...
or a 27:1 ratio at 8,000 rpm.
Old 12-17-2008, 04:16 AM
Bikeguy Joe's Avatar
I don't think the red line on a crapsman trimmer is over 10,000.
Old 12-17-2008, 10:07 AM
I totally agree.
Hill climber, maybe you're not going 23 mph with that 3/4" roller.
Old 12-17-2008, 11:58 AM
thanks guys, i forgot to mention that the 25cc 3/4" roller is on a 20" bike, different motor but still 25cc. yeh, the 20.5:1 was not enough on the 26" bike. well the final sprocket was a 44 tooth and now im going to try a 56 tooth, should be 26.9:1 ratio. should be better.
Old 12-17-2008, 11:20 PM
We're still confused.
You must have a jackshaft. Can you describe your gear setup? I'm tring to figure out how you get 26.9:1 with a 56t sprocket.
Old 12-17-2008, 11:36 PM
ok, the trimmer had a gear box, 5.6:1, i added a 12 tooth sprocket to the gear box output shaft, that i fabbed, from 12 tooth spocket to 56 tooth sprocket, these are a 4.66:1. so let me know if i did this right. gearbox ratio times chain ratio, 5.6X4.66=26.096 , sorry misses the "0" before.
Old 12-21-2008, 07:55 PM
With 20.5:1 gears at 7700 rpm, the 25cc engine might've been sluggish at low end, and top speed was theoretically 29.1mph.
With 29.1:1 gears, same engine/same rpm pulls to a more realistic 23 mph with more low end torque.
Sounds reasonable.
Old 12-21-2008, 08:20 PM
well that was fun till the plastic clutch housing broke. i have to pull the clutch/ gear box off and see what to do with it. maybe a gravity clutch friction setup. thanks for all the help. hill climber
Old 12-22-2008, 04:46 AM
comfortableshoes comfortableshoes is offline
your craftsman whacker 25cc had a gearbox? I have had 3 in my shop over the last 6 months. One an ancient 20 year old 32cc had a fantastic clutch set up, no gears though. The next also older, 21 or 25cc had no clutch and no gears, and the last one I've got is a 25cc slightly newer model, and by that I mean that it is from around the 90s and not the 80s like the other 2 has no clutch and no gears to speak of. I've also got a mid 90s poulan that has no gears nor clutch.
Made in china, made better in my garage
Comfortable Shoes Studio Tool Rolls and Pouches
MyMotoredBike.com
Flicker Page
Don't feed the trolls!
