Old 12-13-2008, 09:21 AM
old motorbike's Avatar
old motorbike old motorbike is offline
Default Bent rear axle
My rear axle has gradually bent, causing the wheel to be crooked. It was a 15 speed mountain bike. I did a search and couldn't find a source for a grade 8 axle or all thread. I couldn't find one local. It's a 10mm x 1.0 pitch.
I decided to use an old head bolt for a car. I don't know the grade, but I'm sure its harder after working with it and the size was close. I ground off the old threads and will need to cut down the head for proper length. I bought a new die and threaded most of it. I'll post pics if it works. It cost $6 for the die so far.
Old 12-14-2008, 04:47 AM
tyrslider's Avatar
Thumbs up Re: Bent rear axle
A good quality heavy duty axle is only $15!
FireBelly Cycles and MachineWorks (lol)
Motorized Bicycles, Parts, Tools and Accessories for the Real World!
Email Support@FireBellyCycles.com
www.FireBellyCycles.com
http://www.youtube.com/watch?v=-kNGVCnjJVs
Old 12-14-2008, 05:47 AM
Default Re: Bent rear axle
Thanks, I tried to find a heavier axle at a local bike shop and they didn't have one. Can I get one online?
I'm finding all kinds of troubles. The axle was no problem to make from the head bolt. The threads do not match the bicycle's threads. I took it to a bolt supply house, here and the closest they could determine was also a 10mm x 1.0. They said manufacturers sometimes use generic sizes? This size doesn't match the nuts and bearing races threads. Very close. So I re-tapped them only to find that the bearing races are too hard to tap and the edge of one crumbled.
Unless I can get all the parts, I'm considering going to all 7/16" or 1/2" and use sealed bearings.
I'm also looking for a tool that I can remove the gear cluster because there's a bearing and retainer nut under there.
Old 12-14-2008, 07:56 AM
Walter F.'s Avatar
Walter F. Walter F. is offline
I have found as a rule bicycle axles have two different thread pitches, 24 threads per inch & 26 threads per inch. If this was not confusing enough, most bikes have one pitch on the rear and another pitch on the front. I think it is 26 threads per inch on the rear & 24 on the front but it could be the other way around.
As far as axles, you might try Rini Enterprises in Beaver Falls PA. Hope this helps Walter F.
Old 12-14-2008, 10:11 AM
Thanks Walter,
You're probably correct. The axle was thought to be a 3/8" x 24,(they didn't know about the 26) but maybe it's a 3/8" x 26. that would make more sense. The 1.0 pitch fit, but the 10mm was a little big. I'll need to explore more tomorrow when the stores are open.
Old 12-16-2008, 09:14 AM
I found another bike store in town. The guy had all the parts I needed. Axle, bearings, cones, nuts and a freewheel tool all for $10. He also was quite interested to see my bike. I had it back running last night.
Also checked Rini and they had lots of parts. Thanks to everyone.
Old 12-16-2008, 10:30 AM
tyrslider's Avatar
Was that a chro-mo axle? Seems cheap for all that stuff. You do not want a non-chromolly axle.
