Questions about using a HF 79cc engine
joelnotroll
I am looking at putting a HF 79cc engine on my bike. I have little knowledge of what is needed to have it fully set up.
Im wondering what I need to set it up,(clutch? jackshaft? carb?)
I would like to run it vertically, if that makes any difference.
My plan is to collect all the parts needed from now until december or possibly earlier,then assemble it.
You can't change the orientation of the cylinder on a 4 cycle because it changes where the oil pools. The engine won't lubricate itself properly. A little bit of an incline probably won't matter much, but a 90* or 45* rotate won't work.
A 2 cycle doesn't care how it's turned as it doesn't have a crankcase per say.
Good luck with your future build!
There are plenty of us who are currently building or have completed HF 4 stroke builds that have the cylinder rotated nearly 90 degrees. Many before me have rotated these engines without issue. You just need to remove the oil cutoff switch, and adjust the oil level commensurate with the engine incline such that the oil level is still at the same level with respect to the crankshaft. The oil slinger apparently works the same way.
Here's my bike (called Cheap B@stard) with it's rotated HF 79cc under build:
My apologies. I just learned two things.....
1) Things change.
2) That you can mount an engine like that without catastrophic results.
Makes it to where there are more frame possibilities.
Again, apologies.
I think you should do some research and look at other's builds to see what they have done, rather than asking for an easy answer. I mean no disrespect here, just want to point out why doing the research is better. Number one, you will get a better idea of what parts will work, how they will work and how they should be installed. Number two, you will see that there are a few different ways to build a 4 stroke, and you can be aware of the different options and decide what is best suited to your particular needs, taste and style. You can also be aware of how involved the installation process will be (bolt-on and go vs fabrication). Some, like myself, prefer more of a bolt-on and go while others enjoy fabrication. Also be aware that some custom bikes are not "perfect" right out of the shop. Some builds require fine-tuning and experimentation is all part of the learning curve. There are some instances where you can go with a less expensive part and it can work out great. Other times the cheap parts end up costing you more money in the long run. Looking at other's builds will give you a better idea of what's worked and what hasn't. I'm not saying any of this to discourage you. I just read part of your statement in your op "I'm looking at installing a 79cc and have no idea what parts are needed". Paraphrasing a bit of course, but doing the research will give you a better idea. We can give basic answers here, but there is no one best way of building up a 4 stroke. The research will help you determine how you want your bike built.
Thanks atombikes, I am subscribed to your thread and think your bike is looking great.
thanks bigbutterbean, I am looking for a more basic answer here that will help with my research. I have been looking around and watching the HF 79cc build threads,as well as some others(212cc builds). I already have my 66cc 2 stroke mounted up, but the HF 4 strokes look significantly different.
As I stated I have little knowledge about these, which is why i made a thread asking.
When i look at an image such as this;
http://silodrome.com/wp-content/uploads/2013/02/motorized-bicycle-1.jpeg
I see the clutch and the jackshaft set up. But I dont understand how they work.
I also dont know what that aluminum cylinder behind the seat tube is?
Basically, I fell like I know so little,that I dont even know where to begin searching, but I know once I know a few things, I will be able to go back to the threads I have read and make more sense of them, and will have new key words to search the forums for.
thanks for your help guys
Ok, here is how that clutch works. It is called a centrifugal clutch, and it is called that because it works by centrifugal force. Centrifugal force is when any object inside a spinning circle is pushed toward the outside of the circle. The clutch has shoes and a spring. The spring is designed to expand with a certain amount of pressure, translated to rpm's of the engine (the faster the engine spins, the more pressure is put on the spring). The spring keeps the shoes from spinning out against the drum until it reaches the required amount of pressure to allow it to expand. This is how an engine is able to idle with a centrifugal clutch. There are different springs that allow the clutch to engage at different rpm's. A lighter spring allows for earlier engagement, while a heavier spring allows for later engagement. There are also different weights of shoes that affect clutch engagement, but in the opposite way. A lighter shoe allows for later engagement, but a heavier shoe allows for earlier engagement. From what I have read, a heavy spring and a heavy shoe is the best way to have smooth engagement at almost any rpm. Others have found success with light shoes and a light spring. I'm currently running light shoes and a heavy spring, but getting ready to order some heavier shoes as soon as I have the money. On the subject of jackshafts, a jackshaft is essentially a shaft that transfers driving force from one side of a shaft to the other. It can be a 1:1 jackshaft (same size gear on both sides of shaft) as in the case of the shift kits, or it can be different size gears to achieve a desired amount of reduction, which is how they are normally used on 4 strokes. By reduction, I mean the relationship between the engine speed and the rear wheel speed. 4 strokes need added reduction because they do not have any built-in reduction like the kit 2 stroke engines do, and they are too high revving for direct drive (direct drive is when you have the same size drive and driven gears, and no other gears in between. The maximum suitable rpm range for direct drive is 1500-1800. The harbor freight engines operate at a maximum of about 6000 rpm's). With a jackshaft, you can pretty much choose what size gears you want for your desired ratio. The gear ratio determines the top speed and hill climbing ability of your bike. My bike, which has a 98cc Lifan minibike engine, winds out at about 5000 rpm's and with a gear ratio of 12.44:1, tops out around 32 mph. The 79cc engine winds out at about 6000 rpm's with the governor removed, and with the same gear ratio as my bike will go about 40 mph. You can gear it lower for less top speed and more hill climbing ability. If I ever happen to use a 79cc predator, I plan to gear it down to about 30 mph as well. So you see, there is no real "basic" answer, because you have to decide what you want and find out what of the available options will get you what you want. There are too many different ways to build a 4 stroke, and each one will produce different results as far as looks, speed, handling, and general riding style. Its best to get a general idea of what you want, then compare other's builds to see which ones come closest to what you want, not to copy anyone's build, but just to get a general idea of how to go about building the bike that you want. Because you may realize as I did, once you get into a custom build, its about way more than just how the bike gets from a to b. Although that is the most important part, you are building a custom bike so you might as well customize the whole bike to your own personal needs and wants. You've got a 2 stroke to putt-putt around on, so take your time and plan all the details. Then you'll know what parts you'll want and need, and you'll be able to take your time, progressing as you get the parts you want. Rather than starting out with something basic and only changing things as you go along, which can be a lot more expensive than just building it right the first time. When I built my custom bike, I started with a bare frame and gathered up parts one at a time, not actually building the bike until I had all the parts on the list. I've changed and added a few things since then, but I started with the bike and the parts I wanted.
