Old 12-06-2008, 02:35 PM
mechanickid's Avatar
mechanickid mechanickid is offline
Default clutch wont disengage
i was going down a hill and when i got to the bottom i engaged the clutch and then it wouldn't disengage. the lever is moving but the engine is still moving with the clutch. did something break?
Old 12-06-2008, 05:11 PM
misteright1_99's Avatar
Default Re: clutch wont disengage
Check to see if the cable moves freely with the clutch arm disconnected. My kit came with a frayed cable brand new, and it stuck inside the jacket.
Walmart sell packs of asst. cables for under $6.00.....
"No such thing as a stupid question, just a stupid answer"
48cc Grubee Starfire Round Head......
Old 12-06-2008, 05:15 PM
nope the arm on the engine is moving
Old 12-06-2008, 05:53 PM
Ghost0's Avatar
Ghost0 Ghost0 is offline
Maybe the little pin that hold the clutch actuator in place is broken or fell out. Can you just slide the clutch arm out of the cover?
Design is easy, execution the hard part.
www.sickbikeparts.com
Old 12-06-2008, 05:59 PM
Take the clutch cover off, pull the pin out (in the center of the sprocket) and stick a magnet in the hole to see if the ball bearing is inside there. It should come out with a magnetic pickup, or maybe just lean the bike over and it might roll out. I dont see how you would lose it while riding though, maybe just need to adjust the star nut on the opposite side, turn it in a notch or two...
Old 12-06-2008, 07:38 PM
Bikeguy Joe's Avatar
I'm thinking the cable end just slid a little and when you pull in the clutch, it's not moving the arm enough.
Old 12-10-2008, 04:08 PM
well somehow its working again... thanks anyway guys
Old 12-10-2008, 04:18 PM
jasonh's Avatar
jasonh jasonh is offline
After running the motor for a while, my cable would heat up and the clutch would no longer fully disengage. Could be something like that happening to you.
Old 12-10-2008, 11:34 PM
How did you fix it?
Old 12-11-2008, 04:17 PM
jasonh's Avatar
Originally Posted by mechanickid View Post
How did you fix it?
I never actually fixed it, I had that problem right up till the motor bit the dust. Pretty sure the cable would heat up to the point where it would "give" a little and so not as much tension would be on the clutch arm. I will be getting a new clutch cable to correct that issue though.
I don't think that big spring is much of a heat shield.
