Old 08-06-2013, 11:46 AM
worksuxxx's Avatar
worksuxxx worksuxxx is offline
Default #41 chain on Huasheng 49cc rocks!
If anybody has the Huasheng 49cc 4 stroke engine with the 415 chain, change it!!!! My chain went bad over the weekend, went to Tractor Supply to get a new one, opted for the 41 chain. I thought the gear reduction box (trans?) was the reason for all the noise when riding around. Was I wrong.. It is much quiter with this chain. I also noticed way more power!! The 415 chain robs you of much needed hp. While riding in my subdivision on my hills, with the old chain I could climb the hills without pedaling, but I could feel the engine laboring. Now I climb the hills like I shaved a 100 lbs. I know I can go with a smaller sprocket for more top end speed, and still be able to handle my hills. So I am excited to order my new sprocket today. OH also I can now pedal the bike since there is much less resistance. Not too important unless you brake down. Anybody else like to chime in on the 41 chain upgrade?
Old 08-06-2013, 08:57 PM
CharlieHustle's Avatar
CharlieHustle CharlieHustle is offline
Default Re: #41 chain on Huasheng 49cc rocks!
I haven't turned back since switching from the stock 415 to the #41 chain!! havent tryied the 36 tooth sprocket yet
Old 08-06-2013, 09:01 PM
maniac57's Avatar
maniac57 maniac57 is offline
Been using #41 since the very first bike I built.
First upgrade every builder should try!
(I run two strokes, but better is better!)
If more is better, then too much is just enough.
If you can't afford it, build it yourself.
