| High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. |
12-06-2008, 12:45 AM
any performance mods
hello my name is corey and i am new here? i have had my pk80 installed for a wk now.it is running pretty good. i want to go to a 34 tooth sprocket,it is a 26 " bike does any one know what my approx. speed would be, and if i could get some help on any and all mods to get more tourque and power.i wanna know everything..lol thanx in advance for feedback corey
12-06-2008, 10:50 AM
Santa Cruz Scooter Works
Re: any performance mods
The easiest way to get big gains is with a tuned pipe. It will increase your low and mid range torque.
12-06-2008, 12:35 PM
Your top speed, stock should be between 25 and 35 mph.
12-06-2008, 01:33 PM
also i took off the cover to the flywheel and greased the gears and put some rubber in there to quiet it a lil, i noticed there is what looks to be clutch material, is that normal after a week of running? i am really interested in mods!! mainly right now things i can do by myself without spending to much money at this time. i seen some one said they run without head gaskets, does thta work witout leaking.
12-06-2008, 03:07 PM
hey mate.
Iv never heard bout anyone not running with head gaskets but i would highly NOT reccoment it. i reccon that it would leak a bit. the "clutch" material that u talk about might just be wat was left in there from factory, the same thing happed on my bike.
Im not to sure on cheap mods apart from what easy rider said, a tuned exhaust is a good one. I havent had any need to modify mine anymore, it goes quick enough for me.
Good luck with ur bike. ( have u got any pics)
12-06-2008, 05:00 PM
Intake and exhaust manifolds would be my first mod along with new gaskets, plug and plug wire next, then pipe.
12-06-2008, 10:57 PM
how does the stock plug wire come out of the cdi
12-06-2008, 11:02 PM
You just twist it out counter clock wise and clock wise to install the new one, there is just a screw in there.
Pics in this thread........ http://motorbicycling.com/f3/spark-p...motor-765.html
12-08-2008, 06:19 PM
does a copper core wire have to be used? can i use a automotive wire?
12-08-2008, 06:31 PM
There is no metal in automotive wire, try a tractor supply or a small engine shop, they will have a roll and can cut you a length. Or you can can one with one end attached. I think you want 7 or 8 mil but you may want to verify that.
I also used a hot glue gun to put a nice seal around it and never had a problem in the rain after that.
| Thread Tools |
| Display Modes |
Linear Mode
