Old 12-03-2008, 07:39 AM
Russntustin's Avatar
Russntustin Russntustin is offline
Default Needle bearing on wrist pin LOOSE?
I'm in the process of replacing all the studs on a new build....so I have the head and jug off. ( I want to clean out the stud holes in the case) I see that the piston's bearing on the wrist pin just 'floats' back and forth out of the con rod. Not all the way off but 1/2 way. Is this normal? Doesn't seem right to me.
Old 12-03-2008, 12:49 PM
donuts31 donuts31 is offline
Default Re: Needle bearing on wrist pin LOOSE?
Yes, normal but normal doesn't mean its right.
