Old 12-02-2008, 06:14 PM
bumleg's Avatar
bumleg bumleg is offline
Default 2 min. and 100 ft
i just put together my chinagirl and it fired right up
however it only ran for about 2 minutes when it just stopped .
i was still doing figure 8s in the driveway..
i cannot get the thing to fire up again,
i think i lost 5 pounds peddling around ..
i has what appears to be a strong spark, nice and blue.
it is getting fuel, had the carb off to make sure no dirt was in the jet.
.. would it be possible it is out of time.there is or was no backfire to suggest shearing off a key.
im at a loss, it wont even attempt to fire.
any ideas?
Old 12-02-2008, 06:21 PM
thatsdax thatsdax is offline
Default Re: 2 min. and 100 ft
If you have the wires bass akwards on the CDI that will put timing of the spark 180 degrees off. If you have a weak spark that you can see, it will no longer spark under compression. If you have a strong spark and still no joy, then it is a fuel issue. Disconnect your fuel line from the carb and drip some fuel directly into the cylinder by removing the spark plug. When you pull your plug might as well do a plug chop which means pull the plug and look at the tip. Is it wet? Dry? Black ? Brown? If it is dry, then drip some fuel into the cylinder, replace the plug and see if she fires and runs for a few seconds or at least pops. Let us know. Thanks..
visit www.thatsdax.com
Old 12-02-2008, 06:43 PM
bumleg's Avatar
the wires are plugged in to the corresponding colors.
(however i do not have the killswitch hooked up.so the white wire is temporarilly taped off.)
it seems to be strong blue spark. it seems to be getting fuel because after a while it started dripping out the muffler.
the plug is wet and unburnt.. i tried puting some fuel in the plug hole and still never got even one kick...
i peddled around with the fuel shut off ,thinking it may have flooded, still no put put..
i am always working on something that makes a carbon footprint,
but this one makes no scense, appears to have fire and fuel, seems to have compression, but it wont make an unassisted noise...
thanks for the reply.
Old 12-02-2008, 07:04 PM
mechanickid's Avatar
mechanickid mechanickid is offline
thats amzing...ly srtange, i would take it to a hill and ride down trying to start it, thats all i can think of.
Old 12-02-2008, 07:30 PM
misteright1_99's Avatar
I would adjust the clutch, it sounds like the clutch is slipping under compression.
"i peddled around with the fuel shut off ,thinking it may have flooded, still no put put.."
"No such thing as a stupid question, just a stupid answer"
48cc Grubee Starfire Round Head......
Old 12-02-2008, 07:59 PM
bumleg's Avatar
thanks for the tip, but it is not slipping, it is definetly rolling over.
keepthe ideas coming guys
Old 12-02-2008, 08:18 PM
Pablo's Avatar
Pablo Pablo is offline
Plenty of compression (head nutz tight)??
Old 12-02-2008, 09:18 PM
TexasDav's Avatar
TexasDav TexasDav is offline
I had the same exact problem with my motor when I was first breaking it in. I was so frustrated. I had spark, fuel but I would peddle for blocks untill I just could not peddle no more, tried every trick I knew including sarting fluid. Called the pople I bought the motor from, They said change the plug, I said it has spark because I pull it and seen blue spark, and I tryed new plugs but I got the one they recomeded NGK B6HS, and it finally started. Took it awhile to run good but it was a weak spark. I don't know if that is your problem but a plug is cheap. Good luck.
Old 12-02-2008, 09:41 PM
lennyharp's Avatar
lennyharp lennyharp is offline
I had a clutch that slipped and would not start. Sounds like you may have a similar problem if gas and spark are getting to a sealed chamber with good gaskets. A lot of ifs there but try tightening the clutch with the star nut.
LennyHarp of Lenny's Bikes & Things
http://lennyh.com
The true value of a man is not judged by what he has, but rather by what he can do without.
"We are what we repeatedly do. Excellence, then, is not an action, but a habit." -- Aristotle
Old 12-03-2008, 05:37 AM
Bikeguy Joe's Avatar
Check for the dreaded air leak and try a new plug.
