Old 12-01-2008, 10:55 PM
ran49's Avatar
ran49 ran49 is offline
Default Routine (rebuild) Maintanance
Just wondering if any of you guys ever change rings and wrist pin bearing on any schedule or just run it until a problem becomes obvious.I have about 1400 mi. on my Dax 70cc.and it run as good as new.I have an extra set of rings and a new bearing and would much rather do this work in the winter while I'm not riding it than in the summer.I guess you can do a compression test but is there any way to judge the state of the bearing.Thanks Ron
Old 12-02-2008, 02:30 PM
jasonh's Avatar
jasonh jasonh is offline
Default Re: Routine (rebuild) Maintanance
If you pull the cylinder off, I think you can check the bearing for excess play by wiggling the piston around. I'm not 100% sure but I believe it should only move back and forth in one direction.
Old 12-02-2008, 05:31 PM
Bikeguy Joe's Avatar
You'll hear it long before it goes. As soon as you hear it rattling, change them.
Old 12-02-2008, 09:37 PM
jasonh's Avatar
I didn't hear any rattling before my rings rotated and trashed the cylinder.
Granted, the pin came out....
