Old 12-01-2008, 08:28 PM
RLorange RLorange is offline
Smile Piston Skirt mod for improved performance?
Hello Everyone!
I have been trawling through posts about porting and noticed a few things which stand out.
I have successfully removed both the bottom gasket and head gasket in order to boost compression and performance (Not at the same time!). Both should raise compression by the same ammount as they are roughly the same thickness BUT having tried both they are NOT equivalent. Losing the bottom gasket gave me a better boost, my engine could just truck up hills at 3/4 rev (aT WOT). SO I am assuming that the slight port timing difference shifted the torque to lower RPM.
I am intrigued by the Mod which removes an arc of material from the piston skirt which partially block the inlet port during fuel transfer, if anybody has tried this please share your results.
I am going to find a better Silicon than the one I used before to seal up the bottom of the cylinder and make this mod permanent, then I might start to shave some metal from the bottom of the skirt to see if I can squeeze out even more performance. Seems to me to be a safe mod if effective as the skirt has no loading on it.
Old 12-01-2008, 09:24 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Default Re: Piston Skirt mod for improved performance?
Be careful! Raising the compression also raises the engine temp. (It will probably hurt most when the summer comes!)
Keep us posted & post pics!!
Old 12-01-2008, 10:44 PM
trackfodder trackfodder is offline
You are right about the low end power gain. You dropped your ports so it retains combustion pressure longer and the increased c/r probably helps, but of course the top-end power suffers KW
Old 12-01-2008, 11:29 PM
I was reading that the top end should suffer but I didn't notice this. Then again I don't usually let my engine hit the high revs for long. Being able to power up hills is far more valuable to me. On Main hill I ride It gets up at maybe 25kmh with the mod at WOT and only 20 or a bit less without the engine will never max out RPM wise on these hills.
Old 12-02-2008, 02:20 AM
Also in response to Venice Boy, I have solved my engine heat problem by using an oil additive treatment called Bi-Tron. It is a 2-stroke specific oil product which is unique in that it is 100% pure petroleum (Mineral) derived Parrafin based oil which is treated to make parts of the oil molecule polar which then stick better to metal in effect giving the oil surface tension sticking properties like other polar fluids. This sticks to a clings to all components of the metal it comes in contact with but also sticks to the regular 2-stroke oil. The reduced friction is remarkable and my engine never gets too hot even after a long slog on hot days. The polar oil leaves a layer coating the metal which also seems to make the fuel flow more sticky so it has the same effect as polishing the ports.
Really great stuff. I highly recommend it!! especially if doing any kind of MOD
Old 02-21-2009, 10:40 AM
mechanickid's Avatar
mechanickid mechanickid is offline
bitron is amazing! watch this if you haven't yet!
YouTube - Bi-Tron Lubricant Test
its only too fast if you cant stay on!
Old 02-21-2009, 11:45 AM
2door's Avatar
2door 2door is offline
Where is it available? Haven't seen it anywhere here yet.
Old 02-21-2009, 11:54 AM
so far the only place i know of is this website
Bi-Tron Australia - BiTron Sales
