Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Motorized Cruiser Bicycles
Motorized Cruiser Bicycles The beach cruiser has always been great bicycles to motorize. They just look good with a motor. Use this section to share and discuss about motorizing this classic.
Old 06-03-2013, 04:57 PM
Master-shake's Avatar
Master-shake Master-shake is offline
Default coaster brake issues.
I have this onyx 29 inch moto-bike.
My question involves the coaster brake. For some reason after I took it apart the it has started making the pedals turn just by moving the wheels. Nothing so serious that it's like a fixed gear, but when I put no pressure on the pedals they will move with the wheels movements. lightly and they will stop if i have my feet on em.
Did I tighten the coaster to tight or something? Do I need to have the coaster set in a certain position before installing? (I have the internals of the coaster brake assembled correctly, at least in the correct directions/placements) I'm sure I could have solved this by now, but this extra chain and the inability to put my bike on a stand is kicking me in the face.
Just post me a link of a youtube video that shows the do's and don'ts of reinstalling the rear wheel, cause I seem to be screwing it up.
Old 06-03-2013, 05:15 PM
bill2781 bill2781 is offline
Default Re: coaster brake issues.
I haven't fixed coaster brakes in years so I hope im correct on this you might have it to tight.
Old 06-03-2013, 05:20 PM
yeah I've loosened the entire assembly a bit and it stopped the issue but it cause the rim to wobble on the bearings. Maybe I need a bushing/washer or something...
Old 06-03-2013, 05:40 PM
your could be right on that id give it a try and see what happends
Old 06-03-2013, 07:56 PM
Toadmund's Avatar
Toadmund Toadmund is offline
Maybe now you are just too loose, you may just need to find the sweet spot?
I love my Motor Bicycle, I love Beer, I'll try not to like them both at once.
Old 06-03-2013, 09:40 PM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
yeah, you gotta find the sweet spot.
when the cones are too tight it puts pressure on the drive sprocket, and that causes it to pedal forward. cones too loose and it wobbles.
it just takes some patience.
Old 06-05-2013, 04:57 PM
konig44's Avatar
konig44 konig44 is offline
Check to see if the dust cover cap is pressing on the bearings
Old 06-12-2013, 01:38 PM
rangefinder rangefinder is offline
Find the sweet spot and get the adjustment bolts tight against one another.
Get the wheel on the bike, then before tightening it into place, turn the whole deal until the brake arm is up where you attach the band around the chain stay. Now Move the wheel back to tension the chain. Finally tighten it all up.
Do not move the brake arm into into place with the axle nuts tightened.
A bike shop, if you bring in the wheel only, charges about $10-$15 for an adjustment.
Old 06-12-2013, 02:34 PM
bairdco's Avatar
Mount the brake arm loose, so it doesn't spin. then adjust the wheel for chain tension .
Old 06-12-2013, 03:18 PM
xseler's Avatar
xseler xseler is offline
Cone adjustment wrenches are an almost must have when trying to get this right. I finally had to break down a get a set for mine.
Good luck!!
You're never lost until you run outa gas.
MotorBicycling.com
