Old 11-24-2008, 10:15 AM
squire squire is offline
Default bogging down
well first off, im totally happy with my motor and this awesome froum, very very helpfull, thank you!
but now another sitution has arised! my motor is new and not even 10 miles on it yet, but it seems when im going full throttle or some time even when im on the way to full throttle the engine, boggs down seems like im not getting my engines full potential.... could just be a simple adjustment? or maybe its just the motor breaking in? any clues or tips.....and also it when i put the choke on the engine will just cut out..
but thanks for all the hjelp
Old 11-24-2008, 10:19 AM
jasonh's Avatar
jasonh jasonh is offline
Default Re: bogging down
Once your motor is running, putting choke full on will usually kill it. I don't have a kill switch, so that's how I stop my motor.
As for the bogging....What is your gasil ratio? Have you checked spark plug gap? Checked the color of the plug?
Old 11-24-2008, 10:20 AM
ibcnya's Avatar
ibcnya ibcnya is offline
open your spark plug gap?
Old 11-24-2008, 11:12 AM
thanks for the replies
gas ratio is 20:1 what would be a idle gap in the spark plug? and im not sure what you mean by Checked the color of the plug?
Old 11-24-2008, 11:51 AM
misteright1_99's Avatar
I would start the plug gap at .020 or .025 with a quality spark plug, like a NGK or Champion. Here is a link to pictures of spark plugs. You run your engine, then let it cool, then take out your plug and that will give you some idea of the ai/fuel/oil mixture being correct. Good luck..........
Verrill: Plug Color Chart
"No such thing as a stupid question, just a stupid answer"
48cc Grubee Starfire Round Head......
Old 11-24-2008, 01:13 PM
thanks will do!
whats a good spark plug and wire i could get.. im going to hit up the advance auto parts on the way home.. im running a RAW motor(well thats what the box said)...lol
thanks
Old 11-24-2008, 01:17 PM
jasonh's Avatar
NGK B5HS is what most people use. Nobody around here had the ngk (not even advance), so I ended up getting a Bosch plug at Napa. Pretty much any 7 or 8mm wire and boot will work fine. Anything's better than stock I think.
Old 11-24-2008, 03:19 PM
I use the B6HS I find the cooler plug works better here in Florida, especialy in the summer.
Old 11-24-2008, 03:20 PM
Bikeguy Joe's Avatar
Your plug should be brown or black, but not too sooty or too oily. You could be too lean or too rich, the plug will tell all.
Old 11-24-2008, 04:16 PM
well, none of the auto stores around here have that plug, instead of ordering it, could recommend any other ones? they all carry ngk plugs but none of the b6 or b5HS models.....what else would could i pick up..
