| DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds |
11-22-2008, 06:44 PM
minor bike philosopher
suggestions please
I had the 42cc chainsaw engine break the drive shaft so I junked it but, I am having second thoughts. the drive shaft has about an inch left sticking out of the case. Does anyone have any ideas how I can easily with a minimum of expertise. add a drive to it. I would be willing to go gear and sprocket since I have a scooter wheel complete with tire. sprocket and chain. I can use it as the friction drive if I figure out how to attach the front gear to it. The front sprocket has a 1/2" ID.. The drive shaft on the engine is 11mm smooth now. No threads no keyways nothing...
If you do have any ideas I would appreciate the help. Since I have written it off as junk anything is open to consideration. But I don't have a lot of skills.
11-22-2008, 07:28 PM
The Old Master Motorized Bicycle Builder
Re: suggestions please
It really depends on how hard it is but I think the easiest would be to grind a flat to accept about a 6 MM Allen head set screw. Use a roller drilled 11 MM and drill and tap for the 6 MM set screw.
Next (in difficulty) would be to drill the end for the 6 MM set screw, same roller. Next would be to skip the flat and drill all or most of the way through for a longer 6 or 8 MM cross bolt. Fourth would be to have it threaded.
Just my 2 ¢.
Ted
I wasn't born in Texas but I got
back here as soon as I could.
Help support the forum.
Donate today.
11-22-2008, 07:52 PM
all suggestions are welcome.... I have been kicking around this tell me what you think.
the inside diameter of the sprocket is 1/2" it also has a hole straight through the opening I can install a pin in it.
The shaft is 11mm outside diameter..
Im thinking bronze 1/2" od bushing with a 3/8 id. I have a 7/16 drill bit. Approx 11mm and change.
I'm thinking drill the inside diameter of the bushing. Epoxy it into the sprocket and to the drive shaft so it doesn't move while I drill it.
Drill it all the way through and add a small nut and bolt as a pin or anything else you guys think might work. epoxy the pin as well as the other parts. Do you guys think it would hold together that way or am i spittin in the wind.
11-22-2008, 10:18 PM
Custom Builder / Dealer
Weld the sprocket onto it!
11-22-2008, 10:24 PM
my welding is sooooo bad I'll have to wait till i get good enough to do it.
11-22-2008, 10:40 PM
I doesn't have to look good... just a big fat ugly solid weld!
11-23-2008, 12:14 AM
I might can do that lol.... so how to i center the sprocket the bore is larger than the drive shaft.
11-23-2008, 10:45 AM
weld it as vinice boy said. use a bushing as you described but not bronze use a steel one, car shock bushing comes to mind. think out side the box. good luck.
11-23-2008, 02:07 PM
My suggestion is to weld the bushing onto the shaft, then drill and tap sprocket and bushing for setscrew(s).
The sprocket size might not be optimum. If you weld the bushing onto the shaft, you can always replace sprockets or pulleys.
More versatility.
11-23-2008, 03:24 PM
Well it is ugly as heck but I did it like this. I got a smaller steel tube, I cut it to length then cut the side and wrapped it around the shaft. Then I slipped the cog over it and welded all three pieces together. A little grinding and it seems to be okay. Most likely it will fly apart lol. When I start it.
| Thread Tools |
| Display Modes |
Linear Mode
