Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Mounting Techniques
Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Old 11-19-2008, 05:20 PM
flathead31coupe's Avatar
flathead31coupe flathead31coupe is offline
Default wheel sprocket?
when using the 2x1.25 tires,whats is the best way to get the chain out far enough not to hit the tire, it a coaster brake,the bike is bought from target, its a schwinn windwood 26''
Old 11-19-2008, 05:29 PM
Ilikeabikea's Avatar
Default Re: wheel sprocket?
Some of the sprockets have an offset in them so you can turn them one way or the other for different spacing. Or you might put a spacer between the sprocket and the fiberwashers to move it out a bit.................
Old 11-19-2008, 06:23 PM
Bikeguy Joe's Avatar
The best way to go is to make sure the two sprockets line up so the chain runs straight. If it rubs the tire lightly, it won't hurt anything.
If it rubs more, go to a smaller tire.
Old 11-20-2008, 01:22 AM
Dan's Avatar
Dan Dan is offline
I normally use 2X1.25s. never had a problem with rubbing. Then again, I let new builds "wear in" lol
I want 2 ride my bicycle
Old 11-20-2008, 01:37 AM
xPosTech's Avatar
xPosTech xPosTech is offline
The Old Master Motorized Bicycle Builder
The instructions usually say to put the thin rubber donut between the sprocket and the spokes and the thick one behind the spokes. You might mount the sprocket with the thick one outside the spokes and the thin one behind the spokes.
Like Joe says, check your chain line. It might be pulling the chain over to the tire. In that case, shim the wheel over a little with washers on the left side of the axle.
Those fat tired cruisers usually have little to no dishing. The box store bikes usually don't have any.
How much room is on the other side of the tire? If you have enough of a gap to the regular bike chain you can dish the wheel a little to move the rim over.
Ted
I wasn't born in Texas but I got
back here as soon as I could.
Help support the forum.
Donate today.
