Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Tavern > The Tavern
The Tavern Kick off your shoes and sit back with your favorite beverage and enjoy talking about whatever you like.
Old 11-14-2008, 09:46 PM
H20rider H20rider is offline
Default Rear Drum Brake
After swapping out the manual clutch for an autoclutch on my Whizzer, I decided I'd be more comfortable with two hand brakes instead of the awkward coaster. I tracked down an old Atom rear drum brake (like an Arai) from a Schwinn tandem, installed it.....and......well, ....the stopping power is less than ideal. It functions, but seems mushy and weak. Since, I've juiced up the bike with various speed mods, the braking has become much more important. The shoes look adequate, the cable is taut, and I gave the shoes a light sanding to remove a glaze. I can, with effort, turn the wheel by hand when the hand lever is pulled. The front wheel is the stock drum brake and that one seems to work well.
In short, any ideas for improving this rear brakes power? Ideally, I think the brakes should be able to skid the bike.
Thanks in advance.
Old 11-18-2008, 06:18 PM
Default Re: Rear Drum Brake
Does anyone know about getting replacement shoes for Atom drum brakes? There's a place in England that will reline brake shoes...but the turn around time is probably lengthy.
Thanks
Old 11-24-2008, 01:40 PM
2door's Avatar
2door 2door is offline
You might be fighting a geometry problem here. Are you using the same hand lever that was designed to be used on that drum? If not it's possible that the leverage you're applying might be insufficient to get the most out of your brake shoes / drum. Some newer brake leveres are smaller and will exert less cable force than older styles due to the more effecient brakes used today. Just a thought, but I ran into a similar problem when I installed a front drum on a trike I'm working on. When I matched the brake lever to the brake it worked much better.
Old 11-25-2008, 12:37 AM
Thanks, 2Door
I'm using a a full sized handle, though it didn't come with the brake. I think you're right about the physics issue.
I appreciate the ideas.
Best, Gery
Old 12-07-2008, 10:37 AM
Hot Dog Piggy Tails's Avatar
Hot Dog Piggy Tails Hot Dog Piggy Tails is offline
Oh yeah Geometry sounds like its barely caming the pull or too high geared. But if your pads are too hard? (Ihave a 20 yr old set original and there fine but there STERMEY ARCHER)
In our town they sell the pad lining material itself. Sticky back and Its really stiff. Auto Parts store bud! cUT THE RECTANGLE AND GRIND YOURS OFF.PUT EM ON AND BINDEM FOR AN HOUR
Old 12-07-2008, 01:27 PM
Thanks....that's really helpful.
