EZ1 with 4 stroke advice needed
roofman6
I've got a Sun EZ1 recumbent and I'd like to mount a 4 stroke engine under the seat with the chain going to the crank so I will have gears. I'd like to use the bike for long distance touring and for putting up old mining roads. I don't need speed but do need a strong reliable machine that will handle steep dirt roads. I need advice on how to achieve this and also how to keep the chain noise down. I also would like to know if a 35cc 4 stroke would have the power at low to reasonable rpm or if I should get a 49cc 4 stroke. I don't mind engine noise as long as the engine isn't wrapped up.
It looks like the DAX gear box, 4 stroke engines, and crank freewheel would work.
If there are posts where someone has mounted an engine under a recumbent seat with chain going to the gears, I haven't found them. Any references or advice will be greatly appreciated.
Thanks,
roofman6
Mounted an engine under a recumbent seat with chain going to the gears? Well, I have... but it's not really directly applicable as it's a scratch built tadpole lol
Still, I wanted to suggest that if you've any welding ability you may wish to avoid a crank freewheel setup if at all possible as they're somewhat unreliable with the inexpensive freewheel notoriously bad, the expensive "White Industries" one better, but not bulletproof. Another issue is as it's attached to the pedal arm & with that arm mounted via a square tapered shaft, an offset oscillation or "pulsing" in the drive train is almost inevitable, which can lead to fatigued components & add in the additional, relatively long primary (engine drive) chain and there's going to be maintenance (tension) difficulties as well.
It's not a deal breaker ofc, the White Industries freewheel is a quality unit and many use it with satisfaction - but after going through three freewheels in 5000 miles (cruiser style/two stroke) I'd had enough & sought a different solution for my next build.
Russell's Integrated motor mount and jack shaft offered a wonderfully simple & inexpensive alternative to the difficulties & complexities of a crank freewheel, inspired I adapted the concept & changed it slightly for my application by utilizing only one freewheel bearing, a common & inexpensive BMX freewheel w/a keyed shaft adapter - using a keyed shaft keeps costs & complexity down with commonly available parts, makes gear ratio experimentation and maintenance easy but most importantly that freewheel only takes the pedal load and cannot oscillate as it's mounted to a round shaft;
vid: http://youtu.be/U10xLqTekOw
Just a thought & good luck w/your build, it'll be great to have another 'bent about :D
Barely,
What a great idea. If I understand Russell’s design correctly, you’d use a stock engine and clutch and gear reducer. You would chain this to a freewheel sprocket on the jackshaft and get some more gear reduction, and on the right side you’d put on two sprockets, one chained to the rear wheel cluster and a freewheel sprocket chained to the crank. You would still have a rear derailleur and some gears. When you pedal, you would be turning the jackshaft but not the engine. Looks like a great solution.
I’m concerned about chain and gear noise. I wonder if one of those timing belt gear reducers might be the way to go. Do you have any advice on that?
Thanks so much,
roofman
(Your Tadpole looks awesome. It looks like you used a complete engine and transmission setup to get your gearing).
That's pretty much it, the amount of gear reduction is ofc up to you & my motor being autoclutched, I chose not to have a secondary (engine) freewheel to reduce complexity & increase reliability, also up to you lol
As for making a drive with a timing belt, I've no direct experience but I don't see why it couldn't be done, I'd be concerned about width & I don't think a jackshaft adds enough "chain noise" to warrant it, but then again as before that's also "up to you" which is one of the wonderful things about these builds, the possibilities, the diversity & personalization in design is near infinite, what's "right" only up to the builder.
& thank you, yes I used a Lifan CRF50 (Honda) clone, a horizontal 49cc four stroke w/a autoclutched 3sp transmission - as you might have room, they could be something to consider as they're highly reliable, have a plethora of aftermarket preformance & replacement parts & if you chose/find an automatic, you may not need to jackshaft at all, which keeps costs down to the same or less than a jackshafted 4 stroke. There's some info here if you're interested: Alternate 50cc 4-stroke engine list
Barely,
Thanks for the info and advice. The single “pedal” freewheel on the jackshaft also looks good to me. I’ve watched some videos and letting the engine help in braking would be nice. Right now I’m considering the $100 79cc 4 stroke from Harbor Freight. There are great teardown pictures on the 99cc engine at http://www.affordablegokarts.com/99cc-predator.php
The 22# engine is heavier than I wanted, but these people speak highly of the 99cc engine and I assume the 79cc one would be of the same quality. The gocart people also sell clutches that mount outside of the chain and I might have room to mount a v-pulley there and belt to a large one on the jackshaft. No timing belt though. I would dearly love to not hear chain and gear noise when touring. Your setup with internal gearing probably keeps the chains at reasonable speed and noise levels.
Thanks again,
roofman
Well, I ordered a $99 Harbor Freight 79cc 4 stroke today. Will move the gas tank and muffler, but I’m not sure the engine will fit as none are available in the local stores to measure. I might have to modify the frame.
I’ve decided to go with a friction roller design using stepped pulleys to get a range of gears. I want go up mountain mining roads and I think this will be the most bullet proof design. If the engine operates from 3000 to 6000 rpm and I use 2”, 2.5”, 3” and 4” stepped pulleys, I should get a range of speeds from 4 to 32mph. I’ll put a stepped pulley and centrifugal clutch on the engine and a stepped pulley on a jack shaft under and behind the engine. I’ll fashion some sort of slider that will push and pull the belts from one pulley to the next. I don’t know how easily the belts will change, and might have to use some sort of foot operated tension release. With small pulleys, the belts will wear out rather quickly I expect, but belts are cheap online.
I plan to use a 3” friction roller, possibly stainless steel wire brushes sandwiched and impregnated with resin, and ground slightly concave to fit the tire. I’m hoping that this will not slip and wear the tires too badly. I’ll make some sort of over center linkage to hold the roller in place.
After thinking about it, I just couldn’t see a chain drive getting me up steep mountain dirt roads unless I was using heavy motorcycle chains and gears. I think the 79cc 4 stroke will have the low end power that I want and the belts will be fairly quiet, but I don’t yet know how noisy the roller will be at high speeds, or how it will wear. I expect it won’t be as efficient as a chain drive, and won’t get great mileage.
If any of you have experience with stepped pulleys and friction rollers, I would appreciate your input. I’ll post pictures after I get the engine and start building things.
Thanks,
Roofman6
I used the Honda GXH 50 - 49cc four stroke from staton
My bike & myself, Plus all the other stuff on the bike,....is about 400 Lbs gross & have over 2,500 miles on the motor. Flawless operation, I have a. Sun EZ3 USX delta trike. I mounted the engine directly above the rear axle & made simple spring loaded chain tensioner. Your bike being a 2 wheeler if you use the setup like mine the engine (where it looks like your mounting) would have to be off set due the gear box staton uses on this motor,...but not by much,....maybe 4 inches,.....hope that helps?
Cpt. Stevo,
Thanks for the advice and congrats on your bike. I went with a roller design and am not sure I like it. If I set the roller too loose, it grinds down the tire as it slips on steep hills. If I set the roller too tight, it produces a lot of drag. I have an over the center design with no spring and perhaps some sort of spring mechanism would help. The muffler isn't as quiet as I had hoped for either. I like the weight distribution however. It's a very comfortable ride. I'll see if I can attach some pictures.
Thanks again,
roofman6
