Homemade crank balancing
Hi
I disassembled my engine to balance it
Vibration and a rattling sound I noticed a week ago
Before disassembling I discovered a broken mounting stud, rear mount
At the machine shop we took the broken stud out, and went to balancing
Piston+pin+rings+clips = 70 gr
Light rod end = 35 gr
Total reciprocating weight = 105 gr
I fixed a 55 gr weight to the rod journal
And checked the crank balance using two metal rods (horizontal bubble level checked) and suspending the light rod end with a string
Too heavy
I started drilling the crank added side pieces, and found it had holes in it
Was not enough
I had to drill 1/4 holes through the center crank plates
And balance was perfect
Thing is, when taking the parts to the machine shop, to the local representant to use his extractor, and to the gasket shop to make a center gasket the front gear dissapeared
Grrr
I will see my mechanic today, hope it will be assembled, maybe the gear is in my bag...
Jose
PD I am replacing all studs with automotive grade ones
