Old 01-01-2013, 01:56 PM
Jim C Jim C is offline
Default clutch question - Stinger motor
one more clutch question
The clutch on my new build seems to have an issue. The clutch appears to not disengage. When the clutch lever is pulled in all the way the engine remains locked, the back wheel will not turn. I can turn the back wheel and am turning the motor also. When the lever is pulled the clutch adjusting nut moves out when released the nut moves back but the plate does not move at all. With the nut off I can see the clutch rod move. The only thing moving is the rod and the nut the plate is not moving. This is a SD Stinger motor in a Huffy Cranbrook frame
Old 01-01-2013, 02:14 PM
jimmymc2286 jimmymc2286 is offline
Default Re: clutch question - Stinger motor
My last build did that very thing. I removed the clutch cover, clutch retaining nut and lightly tapped on the clutch, breaking the clutch free so it would move away from the pads. That fixed it.
Made in Who Cares. Assembled in my garage. Jimmy
Old 01-01-2013, 02:42 PM
2door's Avatar
2door 2door is offline
The pads get stuck from the factory during long periods of storage.
Most of the time you don't need to disassemble the right side clutch parts. Remove the left side clutch actuator cover exposing the sprocket and the steel pin (bucking bar) that protrudes from the center of it. Using a piece of wood or a plastic hammer, give that pin a couple of good solid raps. That will usually be sufficient to break the stuck pads loose. Don't hit it with a steel hammer unless you place the wood on the pin first.
Doing it this way eliminates the extra work of readjusting the clutch which, if you don't know exactly how it works, can cause you more problems.
I'm assuming you have the clutch cable adjusted correctly. There really should be no slack in the cable at the engine end where it attaches to the clutch actuator arm. It doesn't take much to keep the clutch engaged if the cable is too loose.
Old 01-01-2013, 08:18 PM
Venice Motor Bikes's Avatar
I can usually break free those stuck clutches by simply pulling in the clutch hand lever & rolling the bike back & forth real hard.
For motorized bicycle sales, service & engine kits in Los Angeles, please visit us at-
Follow VMB on facebook>>>
Follow VMB on Instagram>>>
