Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > 4 Stroke Bicycle Engines & Kits
4 Stroke Bicycle Engines & Kits 4 stroke engine kits are great if you want reliability or do not want to mix your oil and gas. Learn from each other how to get the most out of your 4 stroke bicycle engine
Old 12-27-2012, 04:17 PM
DanielMaia's Avatar
DanielMaia DanielMaia is offline
Default Clutch problems on 4 stroke 49cc engine kit
Hi there guys,
Im having some problems on a 4 stroke engine kit.
The first problem was burn completely the clutch, after 5 miles of use.
It uses a 11T front sprocket. I thought it was because the 40T sprocket, changed for 44T sprocket, bought a new clutch kit on a local store, went for a ride, and it seems the clutch is spinning a lot..in a little hill, even with max throttle, the clutch doesnt "stick" on at all..
Im not heavy (around 150 pounds), the bicycle has about 60 pounds...
I was thinking in the carburetor...if the carb is not tuned properly, it may not accelerate as it should, and the clutch springs does not expand..
What you guys think?
Old 12-27-2012, 04:22 PM
GasX's Avatar
GasX GasX is offline
Default Re: Clutch problems on 4 stroke 49cc engine kit
You should be able to tell if the engine is revving up by the noise. If the revs increase and nothing engages, then it's the clutch.
Old 12-27-2012, 04:34 PM
DanielMaia's Avatar
At no load (on stand) it is revving good. It revs until it reaches a mid rpm (up hill) but down a hill it does 60km/h..at striaght road, does 45km/h
Old 12-27-2012, 05:10 PM
Fugi93 Fugi93 is offline
Originally Posted by DanielMaia View Post
Hi there guys,
What kind of gearbox do you have?
DanielMaia's Avatar
this one:
http://t4bmotorsports.com/uploads/Pr...0/IMG_0872.JPG
Old 12-27-2012, 05:26 PM
Do you have a picture of your bike? I always wondered how the dax gearbox was able to line up. It is very difficult to believe that you could ruin a clutch in 5 miles! Are you running an oil in the gearbox?
Old 12-27-2012, 07:08 PM
ocho ninja's Avatar
ocho ninja ocho ninja is offline
Those gear boxes only have a 3:1 reduction I believe.
So it needs a rear sprocket that has something like 50t to get good reduction for it to accelerate properly
Old 12-27-2012, 07:45 PM
DanielMaia's Avatar
Yes it is. 9 tooth sprocket just after the centrifugal clutch, 27T on big wheel; 11T front sprocket, 44T on the wheel
Old 12-27-2012, 07:56 PM
ocho ninja's Avatar
I heard a 54t for the rear wheel is a good ratio.
If you keep that 44t your just going to keep burning up clutches.
Old 12-27-2012, 07:59 PM
DanielMaia's Avatar
thank you guys,
i will also do some sanding on the clutch drum, it is completely sleek and polished, and may not be good to attach on the clutch pad
MotorBicycling.com
