Old 11-04-2008, 06:51 PM
jacliny's Avatar
jacliny jacliny is offline
Default not returning to idle
my engine seems to remain at high rpms for a quite few seconds before slowing down to an idle. all carb functions seem to check out, could it be an air leak between the carb and intake?
Old 11-04-2008, 07:39 PM
MikeBike's Avatar
MikeBike MikeBike is offline
Default Re: not returning to idle
r u braking it in right now?
Old 11-04-2008, 07:45 PM
jacliny's Avatar
yes i am just started it today. seems to be fine otherwise, but i had to make a new intake mainfold to clear the downtube, just hopeing my welds not leaking.
Old 11-04-2008, 07:54 PM
MikeBike's Avatar
ok
so you welded the carb to the new intake, or your intake to you engine block? or both?
Old 11-04-2008, 07:56 PM
jacliny's Avatar
lol, no just made a new manifold with a 45 deg bend in it
Old 11-04-2008, 08:09 PM
MikeBike's Avatar
o ok, you no it just might be your carb leekin air, mine has a very high idle. but it just stays like that, i need to silicon it
Old 11-04-2008, 08:37 PM
tyrslider's Avatar
Could be a sticky slide as well. But if its an air leak and you spray some wd-40 over where it's leakin the idle will change indicating the leak und vhere it is!
Old 11-04-2008, 09:04 PM
jacliny's Avatar
yup, did just that, its not the manifold i made but where the carb attaches to it, i guess an o ring down in there might help, i dont want to goo it all up with silicon! lol, its a junky clamp arrangement!
