Old 11-04-2008, 02:17 PM
4wdingman's Avatar
4wdingman 4wdingman is offline
Default i been riding with air filter off, can it do harm?
HI
I got a new carby and it won't run with out the cover and air filter off, with it off it doesn't go lean or too rick so can it do any damage?
Thanks
Old 11-04-2008, 02:23 PM
MikeBike's Avatar
MikeBike MikeBike is offline
Default Re: i been riding with air filter off, can it do harm?
i whould leave the air filter on, because you do not want any dust or tiny bugs to bug up you hole works
Old 11-04-2008, 03:38 PM
OSCAR383's Avatar
OSCAR383 OSCAR383 is offline
On A Four Stroke With No Air Cleaner Junk Gets In You Clyinders On A Two Stroke Junk Gets On Your Crank Rod Cylinders And Everywhere In Between
MEASURE ONCE AND CUT TWICE.......WAIT A MINUTE
Old 11-04-2008, 03:51 PM
Bikeguy Joe's Avatar
Set the carb a little leaner, and put it back on.
Old 11-04-2008, 07:52 PM
tyrslider's Avatar
I've noticed that the filter cover is restrictive. You could drill some holes on the back face of the cover. Also Spooky Tooth sells a unifilter that'll give it more air.
Old 11-04-2008, 07:55 PM
ibcnya's Avatar
ibcnya ibcnya is offline
Originally Posted by 4wdingman View Post
HI
Thanks
This is like asking if the bike would run better with a velocity stack, if it works on car Individual throttle bodies then why wouldnt it help make more power on a single carb?
Old 11-04-2008, 08:09 PM
saetta's Avatar
saetta saetta is offline
I have the stock black plastic air breather and I drilled four holes in the area around the mounting screws. I wasn't correcting a problem, however I do feel a difference.
Old 11-05-2008, 07:17 AM
Exellent advice.
Old 11-05-2008, 07:19 AM
Not exactly...he's asking if running with the right mixture and no air filter is a good idea..... it isn't.
Any engine will run better with a less restrictive intake or exhaust if it is tuned correctly.
Old 11-05-2008, 04:01 PM
ibcnya's Avatar
But would a velocity stack improve the perfomance of these engines?
