Old 01-15-2013, 03:16 PM
Dave31's Avatar
Dave31 Dave31 is offline
Default Re: Rag Joint Issue
I've been able to true a wheel with the rag joint mounted but i do prefer to do it with it off.
Old 01-15-2013, 04:31 PM
george_n_texas's Avatar
george_n_texas george_n_texas is offline
I have used a rag joint on a couple of builds but never kept the bikes long enough to know so I'm askin those who have ran more miles is there a problem using only the inside part of the rag joint to get away from the wobble issue? It makes the sprocket ride on the base of the hub instead of sorta floating between the 2 rubber gasket rags? I've heard it will rub & break spokes so I did keep a close eye on it when I did it I doubt I ever put over 500 miles on either build.
Old 01-15-2013, 05:08 PM
bigbutterbean bigbutterbean is offline
If you mean running the rubber only on the inside of the spokes and not the outside, it will work fine as long as you have strong spokes. I ran with only the one rag for 3 years on the same wheel with no issues. It does put some extra stress on the spokes, but if you have strong steel 12g spokes it will hold up just fine. The obvious alternative to resolving the issue is to get a sprocket adapter, eliminating any stress on the spokes that would otherwise be caused by the rag joint.
Old 01-16-2013, 10:53 AM
Groove's Avatar
Groove Groove is offline
Thanks for the responses. I believe all my questions have been answered. I've decided to install a brand new rear wheel (wheelmaster 12 gauge steel rim with Shimano 110 hub) and add a MM clamshell hub adapter. So many people touting these things I'm going to give it a try. I've had one sitting in the box for a few months now but my stock hubs didn't have the correct O.D. to accomodate the adapter. Chinese knock off's of the Shimano 110.....
Then in the meantime, I'm going to learn how to true a wheel. Tom you're right, the guys at the bike store make it seem like you need to apprentice for years in order to learn how to properly true a wheel. They point to their certification papers with official gold seal of approval...give me a break! Good to know it's not a black art.. I'll let you know if I'm successful doing this with the rag joint installed like Dave was. (might be a while though before I follow up on this thread).
Last edited by Groove; 01-16-2013 at 10:54 AM. Reason: I have been promoted to Elite status. This is a good day...
Old 01-18-2013, 12:49 AM
SavageBlunts904 SavageBlunts904 is offline
fork out the 100 bucks for a excellent sprocket adapter. always 100% true with the wheel.. then you never need to mess with it again and wont destroy spokes
Orlando FL. Who rides down here?
