Old 11-02-2008, 11:14 PM
cartisdm cartisdm is offline
Default Flew through my gas tank
I filled my tank about 2/3rds full, assuming that would last me a good while.....that was Monday. I ran out of gas Friday. I don't ride that much, maybe like a total of 5 miles. The weather here is very cold (if that makes a difference), I hit a good amount of hills, but I generally try to help pedal if the motor struggles at all.
What adjustments should I make? The stupid cheap casing for the throttle cable broke apart on me already so I have it all taken apart anyway so I might as well tweak the rest of the bike.
Old 11-02-2008, 11:29 PM
Finfan's Avatar
Finfan Finfan is offline
Default Re: Flew through my gas tank
My first thought would be hose clamps on your fuel line and make sure you shut off the fuel valve when not running. There is no way you could have burned that much fuel in 5 miles. Was it left anywhere where some dweeb could have drained it by any chance?
-and-
I'm not lost, I'm exploring!
Old 11-03-2008, 12:07 AM
Large Filipino Large Filipino is offline
Evaporation is not your friend. I'm thinking some gas may have evaporated thru your vented cap.
Old 11-03-2008, 12:18 AM
tyrslider's Avatar
Is that 5 mi each way for a total of 45 or 50 mi?
Old 11-03-2008, 12:44 AM
Now THAT makes sense. 3/4 full in that tank is still less than 1/2 a gallon in fact I think it's closer to 1/4 of a gallon. Even if you went 40 miles total depending on actual capacity that puppy is getting between 100 and 160 mpg.
Old 11-04-2008, 10:23 PM
old motorbike's Avatar
old motorbike old motorbike is offline
I just went thru a whole tank in 2 weeks of just nightly riding around 2 blocks. Maybe 3/4 mile each ride around =1-1/2mi per night x 14 days= 21 miles per 1/2 gal. not near 150 mpg.
Carb needle at top notch and still 4 cycles.
Old 11-04-2008, 10:32 PM
mechanickid's Avatar
mechanickid mechanickid is offline
yes just make sure its not leaking.
Old 11-04-2008, 10:37 PM
The casing on the throttle cable completely fell apart on me already. I was surprised it only took two weeks, but that's probably because I keep it outside (under a tarp). I went to the bike shop and replaced it with a higher quality and while I was at it I completely greased up the throttle, cable chain, and re-ran the cable. MUCH BETTER is all I can say. Plus I moved my washer thingy on the pin in the carburetor, so now its on the second from the top notch. My engine runs a lot lot lot better. I think it was a combination of all of those, I couldn't believe it.
Old 11-04-2008, 10:45 PM
stude13 stude13 is offline
put spare gas in a drink bottle holder.
Old 11-05-2008, 12:11 AM
ha, there isn't a chance in **** I could fit a drink bottle holder on my bike. I barely got the motor inside my small 17'' frame.
Good idea for my friends build though
