Old 11-02-2008, 09:21 PM
bigben77 bigben77 is offline
Default Octane rating??
What is the recomended octane to use for my MB?? I currently use the expensive stuff cause I only buy it a gallon at a time.
Old 11-02-2008, 09:25 PM
NunyaBidness's Avatar
NunyaBidness NunyaBidness is offline
Default Re: Octane rating??
use the cheapest stuff, why pay more when you don't need to
Old 11-02-2008, 10:09 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
I use the cheapest I can find these are not high performance high compression engines.
norms-iron-works.tripod.com
Old 11-03-2008, 12:43 AM
tyrslider's Avatar
Talking Re: Octane rating??
I use 87 octane (regular) unleaded from a good nationwide station Chevron, Shell, Texaco, etc. Arco and Citco and all that other econo stuff is really inferior. My new cars have not run as good on it. So I figure a motor as unsophisticated as these might be more suseptable to issues from it (I read this as I write it thinking the opposite may be true now I'll have to compare). Also there is not only no benifit to using high octane on these motors it is not good for them in the long run.
High octane gas needs higher compression to burn properly, about 10:1. These motors are about 6:1 compression. Lower Octane Gas Is More Flammable at Lower Compression and Too Flammable (explosive i.e. preignition) at Higher Compression. Pretty much the reverse is true for high octane gas
