Old 10-30-2008, 10:30 PM
noob noob is offline
Default chain tensioner
i was fiddling with some stuff on my bike and 5 miles down the road my idler pulley came off... ididnt tighten it down enough. where can iget a new pulley
Old 10-30-2008, 10:53 PM
brobie brobie is offline
Default Re: chain tensioner
I really like the one that ThatsDax sells. I replaced the one that came with my kit with theirs. It has a ball bearing in it that made things run smoother for me. Some other people remove the tensioner altogether.
Old 10-30-2008, 10:59 PM
OSCAR383's Avatar
OSCAR383 OSCAR383 is offline
i made a custom tensioner mount that welded to the bike frame ...... and then didnt even use it
MEASURE ONCE AND CUT TWICE.......WAIT A MINUTE
Old 10-30-2008, 11:02 PM
misteright1_99's Avatar
This is a simple mod.................
http://motorbicycling.com/f6/spring-...ioner-890.html
"No such thing as a stupid question, just a stupid answer"
48cc Grubee Starfire Round Head......
Old 10-31-2008, 02:14 AM
Cool Re: chain tensioner
is there a downside to going without the tensioner??
Old 10-31-2008, 08:23 AM
Bikeguy Joe's Avatar
I replace them with a skateboard wheel with ceramic bearings.
Old 10-31-2008, 11:03 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
I'm pretty fond of the skateboard wheel too I thin them on the lathe and cut off the outer rubber or what ever that stuff is then make a little shoulder on each side seems to work very good.
Norman
norms-iron-works.tripod.com
Old 11-01-2008, 02:09 AM
niinnn niinnn is offline
Rollerblade wheels are also really good as they are already narrower and have a harder compound to the urethane so they last alot longer.
Old 11-01-2008, 08:58 AM
I grind the groove the old fashioned (or hard) way- on a bench grinder.
Hey Norman- I never knew there was an "outer tire" on those things and I was grinding the groove into my first one and the "re-tread" flew off like a road gator from a 100mph semi!
Old 11-03-2008, 05:15 AM
You can buy them for downhill bikes but they are a rip off $ and you dont get to make it yourself
