Motorized Kickslead
Re: Motoized kickslead
Looks like a heck of a lot of fun!
Not gonna happen here though, it was 28c today. Still wearing shorts for the morning dog walk.
Thanks for the videos.
B.
B.
I'm jealous of you, here is almost winter snow. rain, cold ..........:( 7 months to the summer
Cool . I have thought about building a motorized dog sled before .
Can't wait to see some progress pics on this .
Now I have started with the frame to the kick sled. I use only recycled materials. pipes to the frame comes from an office desk. I will cut off most of mini dirt bike frame, and only use the backswing and engine mounts
An update. changed little on the frame. tested the handlebars
Some more pictures of frame construction
Now it seems that the winter is back! cold and snow again. Some more construction photos! Testing how the the engine should fit in the frame, also made a new handlebar that fits better to the design. Tried also the tank that I should use
Merry Christmas everyone! Some more construction on my kicksleed, has now mounted engine, still have to weld all the pipes and fittings. unfortunately is malfunctioning the weld, but it is only to repair it
Have started to build a snow chain to the rear wheel. Not quite finished with the length, etc., but a beginning. Need probably move out of the rear sprocket a little bit of clearance to the chain
This is AWESOME i have never seen anything like it here in the states. Would be fun to start something like that here.............Curt
I see the runners are thin what size are they?
How far off the ground is the runners with the wheel contact to ground yours looks like it is sitting flat on the table?
I appreciate you like my "hobby project". The measure of The runners (or as we say here in Sweden " medar ") 30 mm x 6 mm, they are not made to go on loose snow, but on ice and hard-packed snow on winter roads here in northern Sweden. The drive wheel must be some cm below the runners to get sufficient grip to the surface. I will probably make a plate that you stand on attached to the swingarm, then you get enough pressure on the driving wheel
