Old 10-28-2008, 07:54 PM
pO0n RaiD3R pO0n RaiD3R is offline
Default T mounting bracket
So... I did not get that bracket in my box but was asking, does that bracket help keep the bike from vibrating?
What other benefits does this mounting bracket help with?
Thanks
Old 10-29-2008, 01:27 PM
Default Re: T mounting bracket
anybody know what these brackets really do? Im going to look all over and see just how many people have these brackets.
Old 10-29-2008, 02:03 PM
Dan's Avatar
Dan Dan is offline
Not sure which bracket you mean? One of the drill threw your frame ones?
I want 2 ride my bicycle
Old 10-30-2008, 02:20 AM
No. I will give you al link to it.
http://motorbikeworks.com/directions...ions%20PDF.pdf
It is page 15.
And also when I put my sprocket on the bike does it need to rest fully on the spokes or can it rest close because I am going to put the rubber pad on it anyway. In the directions it also says I need to file the hole in the spokes bigger so the sprocket can rest on the spoke.
Thanks for any input on this
Old 10-30-2008, 03:35 AM
lennyharp's Avatar
lennyharp lennyharp is offline
That is a bracket that Livefastmotors kits use to mount the motor to the down tube of the bike. Do you have a LiveFastMotors kit? If not you will have some other way to mount the motor. You definately need to mount at least 2 places to have a secure motor. The sprocket mounts on the hub with the rubber/fiber disk inside and outside of the spokes sandwiching the spokes. The sprocket does not touch the spokes but the rubber piece.
LennyHarp of Lenny's Bikes & Things
http://lennyh.com
The true value of a man is not judged by what he has, but rather by what he can do without.
"We are what we repeatedly do. Excellence, then, is not an action, but a habit." -- Aristotle
Old 10-30-2008, 03:49 AM
Dan's Avatar
Dan Dan is offline
Oh, if you do not need it, your better off. step 21 shows it well. Is to correct for large down tubes.
Old 10-31-2008, 05:34 AM
Well... I have a large down tube and tonight I tried to put the engine in and need that bracket. Does anybody know of another way to fit the motor mount around a big tube? Im starting to think that the T bracket is kinda lame. As in it does not look cool.
Old 10-31-2008, 05:42 AM
lennyharp's Avatar
It's not lame if it works and it will if you fit it carefully. Here is datz510's solution to oversized tubes that will take a little more skill and effort to build, but is nicer...
http://motorbicycling.com/f15/rotten...la-2308-4.html
http://lennyh.com
Old 10-31-2008, 07:52 AM
Bikeguy Joe's Avatar
http://motorbicycling.com/f6/oversiz...olved-171.html
