Re: Oils and lube (haha lube)
I use Marvel Mystery Oil on just about everything that moves....use grease on the gears inside the ride cover (just a little) and the clutch pivot point where the arm pushes the rod and ball. Remove the right side cover to get to that.
Check your wheels once every couple hundred miles and re-pack as needed.
