paul
I am going to try and give a comparison of the golden motor magic pie 3 motor and the new smart pie motor. I am using a trek 3500 disk mountain bike and only switching out the 2 wheels with the motors on them. Using same controls battery ect. Only difference is the smart pie I have a mountain bike tire and the magic pie I have a street tire on which really doesn’t make much difference. Both tires at 55 lbs. myself I weight 210 lbs. The battery I am using is a golden motor 48 volt 10 ah battery.
……………………………………………………………Magic Pie……………………………………Smart Pie
Speed flat surface………………………………28mph……………………………………………..24mph
Distance before charge no pedal assist..17 miles………………………………………..21miles
Regenerative Braking……………..helps stopping big time………………………….very little help braking
Hill climbing steep mountain…..slows to around 17mph………………………….drops down to 12 mph
Quietness………………………………………..…quite…………………………………………………..even quiter
Handling………………………………………………good…………………………………………………..great
Weight………………………………………………..25lbs………………………………………………….10lbs.
Power from stopped position……………..…..good……………………………………………….fair
Coasting or freewheeling......................good........................................great
The regen braking I do not know how much it charges the battery however my research says not a whole lot. I like the regen because it uses the motor to help slow you down. As far as hill climbing both motors will do 20mph uphill with pedal assist. Best way I can explain pedal assist is it is like pedaling down hill to get more speed however you are going up hill. About the same amount of strength needed. Distance per charge can be increased significantly by using pedals to help start and when climbing any hills
I have about 1000 miles on the magic pie and 100 and the smart pie. I like them both however I will most likely stick with the smart pie. Reasons is I like the way it handles and also 15 lbs lighter is a lot when carrying up the stairs to my condo lol. The magic pie 3 I usually ride around 25mph so the difference in speed is next to nothing in the way I ride.
