Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Mounting Techniques for Bicycle Motors
Mounting Techniques for Bicycle Motors Every frame is different. Share and ask questions about mounting your engine kit to your frame or rack
Old 09-17-2012, 12:00 PM
rexfan10 rexfan10 is offline
Unhappy Replacement rear engine mount
Hi, i had a strange noise coming from my bicycle engine the other day, and as i was making sure every nut and bolt was tight i came accross the fact that Part of my rear engine mount had come off/fell out. Its a little hard for me to explain and like they say: "a picture is worth a thousands words." So here ya go :
( sorry about it not being properly focused )
Basically one of the threaded bolt things rattled its way loose and fell out the
back. If somebody could tell me where i could buy one or what size the bolt and nut are, and how im to go about putting in the new one i would be much obliged. Thanks, Ruan
Old 09-17-2012, 02:15 PM
MotorBicycleRacing's Avatar
MotorBicycleRacing MotorBicycleRacing is offline
Default Re: Replacement rear engine mount
Those threaded bolt thingies are called studs and the size is 6 mm 1.0
Hopefully it didn't break off in the motor.
Old 09-17-2012, 04:00 PM
Hi, Thanks for the sizes. im afraid it has broken off in the motor do you have any tips on getting it out? Thanks, Ruan.
Old 09-17-2012, 04:03 PM
Do you have a pic of the broken off stud?
is there any part of the stud sticking out or is it flush or even broken inside?
Do NOT do anything in haste as you can make the problem much worse.
Old 09-17-2012, 04:50 PM
Hi, there is a tiny bit of it still sticking out, i might be able to clamp it with some pliers but am worried on clamping it so hard that it sort of squashes it leaving me with nothing to grip with. Heres a pic:
You can see just how little of its exposed as you can only see one bit of the thread. Its also in a very awkward place so to get it out id have to take the engine right off the bike
Old 09-17-2012, 05:06 PM
Did you use any loctite on the stud?
Take the motor off the bike.
There are a few ways to remove the stud depending on what tools
you have .
Do you have access to a welder?
You can weld a stud or nut to the broken piece then unscrew it.
Personally, I would file the broken end of the stud nice and flat.
Center punch the middle of the stud very accurately.
Drill a 1/8" hole making very sure it was centered and going in straight into the stud.
Once you have the hole drilled try a larger bit then reverse the drill and sometimes
the stud will come out.
If not drill the hole larger so it is the right size for an EZ out.
I find that the square EZ outs work the best.
Be very careful when you turn the EZ out as they break off fairly easily
and they are very hard steel so almost impossible to remove.
The last option is to keep drilling all of the stud .out and re-tap the hole.
Old 09-17-2012, 05:58 PM
2door's Avatar
2door 2door is offline
If you have a Dremel tool and a cut-off wheel for it you can grind a screwdriver slot in that stud and possibly back it out with a screwdriver. If you used Loctite on the threads,
sorry but, good luck.
Old 09-17-2012, 06:14 PM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
you can also buy left handed drill bits that are used to remove broken studs like that. they sell them at Harbor Freight for pretty cheap, but i dunno how easy they are to get in scotland.
the tip above from tom is what i'd try first.
Old 09-18-2012, 02:38 AM
Hi. The engine came with the studs in so i am unsure wether the seller/manufacturar used loctite on them. Im also afraid i have no access to a welder, punch or dremel I was going to try using theese clamp/plier things we have, and if that failed go to a very mechanically knowledged friend of mine who does have a grinder, and probably every other tool mentioned above. Thanks for your help, Ruan.
Old 09-18-2012, 05:08 AM
JonnyR JonnyR is offline
the best way to take it out is with the easy out mentioned above
Are you callin' me crazy! just cuz i got a hotel in my foot doesn't make me a boogali moogali moogali
Schwinn jaguar with a 66cc flying horse
they all run fantastic till they don't
smoke tires not drugs
YES! YES! JESUS H. TAP-DANCING CHRIST... I HAVE SEEN THE LIGHT!
http://www.youtube.com/watch?v=YoPVC4YxDlI
http://www.youtube.com/watch?v=y0O7_...eature=related
MotorBicycling.com
