Old 10-24-2008, 09:56 PM
4wdingman's Avatar
4wdingman 4wdingman is offline
Default after run in oil to gas?
hI I HAVE A CHINA GIRL AND I RUN IN ON 20:1 CAN I GO TO 32:1 CAUCE IT SEEMS TO BE DRINKING A BIT TOO MUCH GAS.
THANKS
Old 10-24-2008, 10:31 PM
NunyaBidness's Avatar
NunyaBidness NunyaBidness is online now
Default Re: after run in oil to gas?
that is what I've seen recommended the most after it's run in
Old 10-25-2008, 12:03 AM
tyrslider's Avatar
That is the correct ratio. Anywhere in the 30-33:1 is optimal!
Old 10-25-2008, 08:40 AM
Bikeguy Joe's Avatar
If you are running a bushed engine, go with 24-32 to 1. Bearing engines 30-32 to 1.
Also, look at your plug, you may be running with the carb too rich.
Leaning the oil to fuel mixture will richen the fuel to air mixture.
